Which on of these two motor mount inserts will give me the best results?
Old Dec 25, 2005 | 08:52 AM
turbotime's Avatar
Default Which on of these two motor mount inserts will give me the best results?
Ok I want to reduce the amount my engine moves, I think my torque mounts are ragged so i think reinforcing them will give me the best result, but then i was also thinking of just doing all the mounts.
Heres the catch:
I am looking for reduced motor travel with as little chassis vibration as possible
so here are the choices:
Engine Mounts(R+L):
http://cgi.ebay.com/ebaymotors...70331
Torque Mounts/Rear Mount:
http://cgi.ebay.com/ebaymotors...70273
Old Dec 25, 2005 | 09:24 AM
s2kdre's Avatar
Default Re: Which on of these two motor mount inserts will give me the best results? (turbotime)
http://jimfab.com/
im using theses and they are really good.
Old Dec 25, 2005 | 09:30 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Which on of these two motor mount inserts will give me the best results? (jdmhonda)
inserts are no replacement for busted ***/old mounts... replace the mounts and do it irght
Old Dec 25, 2005 | 09:43 AM
turbotime's Avatar
even if i replace it with a new oem one, wont they still be rubber aka weak aka lots of motr movement.
None of my mounts are borken or anything, worst case they are worn...
Im saying i dont want to shell out big $$ for oem replacements just to find out they dont do **** to help my problem....
Old Dec 25, 2005 | 11:26 AM
turbotime's Avatar
up
Old Dec 25, 2005 | 12:15 PM
tilt's Avatar
general consensus is prothane tends to be a bit stiffer than es. They both cause vibrations but ES should be slightly less. My suggestion would be to use the es inserts on the ac and transmission side only and go from there. if it's still too much flex, add the rear and/or swap with prothanes.
Old Dec 25, 2005 | 12:23 PM
turbotime's Avatar
cool good advice so your saying use the roque mounts inserts, see how it is, then if it still needs stiffening try the rear insert as well.
Im pretty sure its the torque mounts, they have 247k mi on them, i think i may just get new torque mounts and torque mount inserts as well.... does that sound like an ok plan?
not sure what the lifespan is on stock tmounts
Old Dec 25, 2005 | 12:32 PM
tilt's Avatar
Default Re: (turbotime)
Yes, I was referring to the torque mounts.
With 247k, definitely replace those mounts.
Some people are sensitive to noise/vibration/harshness. If you think you are one of those people, just replace the stock torque mounts and go from there. If you dont mind a little extra NVH, then by all means get the inserts.
Old Dec 25, 2005 | 12:42 PM
turbotime's Avatar
Default Re: (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">
hahah yeah i shoulda known! thanks!
Old Dec 25, 2005 | 12:56 PM
turboteg2nv's Avatar
Default Re: Which on of these two motor mount inserts will give me the best results? (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">general consensus is prothane tends to be a bit stiffer than es. They both cause vibrations but ES should be slightly less. My suggestion would be to use the es inserts on the ac and transmission side only and go from there. if it's still too much flex, add the rear and/or swap with prothanes. </TD></TR></TABLE>
The rear mount is usually the one to make the most difference since it sees all the front/back movement..
In my experience, I used the ES kit and only did the front two because I was lazy. Once I did the rear mount, it was night/day difference in acceleration. (virtually no wheel hop)
Cheers and Merry Christmas!
Old Dec 25, 2005 | 01:19 PM
turbotime's Avatar
good info! ill replace my tmounts first since they are worn dead and i know they have a lot to do with controlling torque movement (thus "torque mount" )
But if the new tmounts dont fix it i will be getting the insert kit and it comes with inserts for both tmounts and the rear...
thanks Merry Christmas to you too!
slowboy90
Aug 16, 2010 04:56 AM
ImPuLsIvE
Dec 19, 2007 01:23 AM
lurkin' eg
Nov 30, 2007 03:48 PM
integrawow
Suspension & Brakes
Nov 10, 2006 09:48 PM
92civiclx
Jun 30, 2003 05:41 AM
