what do i need to do to put typer pistons in b20
Old Dec 25, 2005 | 12:33 AM
kevs-ej1's Avatar
Default what do i need to do to put typer pistons in b20
i just recently bought a b20 long block and i would like to do somewhat of a stock rebuild on it........... i wanna raise the compression by putting type pistons........ can i still use the stock b20 rods? or do i need to shave them and such?
Old Dec 25, 2005 | 01:30 AM
BoredNStroked's Avatar
Default Re: what do i need to do to put typer pistons in b20 (Kevs-Ej1)
Dude....your gonna need alot of JB weld to fill the 3mm gap between the piston and cylinder wall.
Old Dec 25, 2005 | 05:57 AM
VALET dude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kevs-Ej1 &raquo;</TD></TR><TR><TD CLASS="quote">i just recently bought a b20 long block and i would like to do somewhat of a stock rebuild on it........... i wanna raise the compression by putting type pistons........ can i still use the stock b20 rods? or do i need to shave them and such?</TD></TR></TABLE>
your going to need after market pistons if you want high/er compression. because stock B20 block have 84mm cilynder walls VS. stock B16/18 have 81mm walls.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoredNStroked &raquo;</TD></TR><TR><TD CLASS="quote">Dude....your gonna need alot of JB weld to fill the 3mm gap between the piston and cylinder wall. </TD></TR></TABLE>
you think this info would really help him?
MERRY X MAS
Old Dec 25, 2005 | 05:59 AM
JCushing's Avatar
Default Re: what do i need to do to put typer pistons in b20 (VALET dude)
i was gonna say the same thing about the jb weld lol, anyway here you go merry xmas
https://honda-tech.com/zerothread?id=1441433
Old Dec 25, 2005 | 10:59 AM
PURPLETERROR aka BIGMATT's Avatar
Type aaaarrr pistons will be fine, it might knock a little at startup
Old Jan 12, 2006 | 10:07 AM
timisyourfriend's Avatar
Default Re: what do i need to do to put typer pistons in b20 (PURPLETERROR aka BIGMATT)
lol you guys are messed up.
Old Jan 12, 2006 | 10:11 AM
fmrprojects's Avatar
Default Re: what do i need to do to put typer pistons in b20 (JZPerformance)
search. this is like the 5th time i seen this question asked
boostnubII
Mar 22, 2012 11:54 AM
zhan28
Aug 4, 2006 04:36 PM
JDM97EK
14
Mar 7, 2006 07:44 PM
boost_addict
Mar 5, 2004 03:23 PM
theSQad
19
Feb 11, 2004 12:12 PM
