Suspension & Brakes Theory, alignment, spring rates....
Keep my springs and get rid of wheel gap?
Old Dec 24, 2005 | 07:01 PM
SovXietday's Avatar
Default Keep my springs and get rid of wheel gap?
I have H&R Sport Springs on my car right now, preferrably I'd like to get rid of the wheel gap that's still there. I was wondering if I could do this and still use my current springs. I'd like to get some Koni Yellows, will that drop the car further?
Car's not being tracked, so I'm looking for a comfortable setup that will eliminate most if not all of the wheel gap. Any suggestions would be much appreciated!
Note* If it helps I will be sporting some Rota Auto-X's come spring.
Old Dec 24, 2005 | 07:20 PM
ekcivic9's Avatar
what shocks are you running right now?
you can drop it further possibly with an adjustable shock/strut.
Old Dec 24, 2005 | 07:51 PM
EK k kay's Avatar
Default Re: (ekcivic9)
If you lower your car using the bottom perch of the Koni Yellows and H&R Sports your car will be slammed and your tires will tuck.. I have that setup and tried the bottom perch and the height was like using ground control coilovers turned all the way down to the bottom. You're only supposed to use the height settings with stock springs anyway.
Old Dec 25, 2005 | 05:34 PM
SovXietday's Avatar
I'm on stock shocks right now.
Old Dec 26, 2005 | 01:26 AM
projectTeG's Avatar
Default Re: (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">If you lower your car using the bottom perch of the Koni Yellows and H&R Sports your car will be slammed and your tires will tuck.. I have that setup and tried the bottom perch and the height was like using ground control coilovers turned all the way down to the bottom. You're only supposed to use the height settings with stock springs anyway.</TD></TR></TABLE>
i wouldnt say that, if he had koni yellow it would take him a bit lower.
to the OP: honestly id say if you wanted to go lower and keep a ride comfort...get some springs that drop the car lower(the race versions)
Old Dec 27, 2005 | 09:24 AM
SovXietday's Avatar
Default Re: (projectTeG)
Alright, I figured that it would be the best way to do it. One last question though, am I correct in saying that I need to get new shocks with lower springs? I do need the advantage of being able to lower and raise the car, so I'd probably switch to adjustable coilovers if I end up deciding to do this, but I do need new shocks right?
DcLs
Suspension & Brakes
Jan 28, 2009 04:11 AM
importfanatic17
Jun 22, 2006 03:29 PM
Goy091
Jan 24, 2002 06:11 PM
siisgood00
10
Sep 17, 2001 05:32 PM
