d16a6 dizzy onto d16z6 head
Old Dec 24, 2005 | 04:21 PM
AJxr's Avatar
Default d16a6 dizzy onto d16z6 head
i searched and searched and every mini-me writeup ive found doesnt show what the modifications look like when putting the a6 dizzy on the z6 head because i know it needs some mod to fit.
anyone have any pics or info?
Old Dec 24, 2005 | 04:23 PM
Rywire's Avatar
Default Re: d16a6 dizzy onto d16z6 head (AJxr)
There is no reason too, thats why... use a z6 dizzy and ecu, that way you can correctly activate vtec.
Old Dec 24, 2005 | 04:48 PM
eL_cArLos's Avatar
I dont have any pics but i have done it, although I was using a full Z6 swap instead of just a head. What I did was cut two of of the ENDS on the Dizzy to bolt it down that is the only way to bolt it up. Or you could just convert to 0bd1.
Old Dec 24, 2005 | 04:52 PM
Mach69's Avatar
The top distributor arm will be the only one that bolts on. The other arm (closest to the firewall) will also 'bolt' up, but the bolt will be OUTSIDE of the arm.
Old Dec 24, 2005 | 04:55 PM
AJxr's Avatar
Default Re: d16a6 dizzy onto d16z6 head (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">The top distributor arm will be the only one that bolts on. The other arm (closest to the firewall) will also 'bolt' up, but the bolt will be OUTSIDE of the arm.</TD></TR></TABLE>
will this be possible to just run it like that? if so then sounds like no mods to make it fit?
Old Dec 24, 2005 | 04:59 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJxr &raquo;</TD></TR><TR><TD CLASS="quote">
will this be possible to just run it like that? if so then sounds like no mods to make it fit?</TD></TR></TABLE>
Yes, of course its possible. But, it wouldn't be smart (and highly ghetto), and I highly recommend going obd-1. Or atleast going pm6 chipped with p28 fuel maps. I would keep some vice grips handy just incase the bolt holding the distributor arm closest to the firewall comes undone. (it happened to me when i was obd-0 d16z6).
Old Dec 24, 2005 | 05:05 PM
AJxr's Avatar
maybe i should just do a z6 swap and say f this mini me nonsense.
Old Dec 24, 2005 | 05:13 PM
NACvicSi's Avatar
You can fab a mount for the other two. There is a thread somewhere where a guy did it, was really easy, just have to get the timing right first.
vtechappy
Mar 23, 2011 11:04 AM
omahaturbocivic
Jun 21, 2009 10:25 AM
shbrown
May 12, 2005 04:36 PM
thenick
Sep 25, 2004 07:20 AM
Mr.Death
Sep 8, 2004 12:52 PM
