rm-01a users please help
i got a used rm-o1a full exhaust from a surplus shop. the b- pipe is missing the exhaust gasket donut, the one whch seals to the flange on the axel back. is there any oem honda exhaust donut i could use instead? i tried using my jdm header gasket, it's way too big. tnx for any help you can give
send an im to user: Tweakmeister
he's with hogens import parts. i believe they carry the fujitsubo exhausts and can probably help you with those missing parts.
kepani
kepani
Did you try a stock header donut from the original header? It should be that size. I however don't have any Fujitsubo's in stock at the moment to double check the exact size.
-Victor
-Victor
i measured the pipe where the gasket seats, its around 60mm od, so im assuming the gasket's hole should be 60mm in diameter too. is the usdm itr header gasket donut this size?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uNF$@#! »</TD></TR><TR><TD CLASS="quote">60mm = 2.5 "?</TD></TR></TABLE>
60mm = 2.36 Inches
60mm = 2.36 Inches
crazyboy
Oct 17, 2011 09:17 AM
Exdeath
Oct 23, 2010 12:32 PM
Eklsv-t
Jan 9, 2008 07:22 AM
AgentJam
Oct 27, 2004 07:51 PM
