awd crx
Old Dec 24, 2005 | 11:40 AM
CRX5Z's Avatar
Default awd crx
thoughts, ideas, what parts to use? I prefer not to use crv parts
Old Dec 24, 2005 | 11:44 AM
slowcarguy's Avatar
Default Re: awd crx (CRX5Z)
Oh man, put on your firefighter uniform...this one is gonna get a lil "heated."
~Alex
Old Dec 24, 2005 | 11:49 AM
Hcivic88's Avatar
Default Re: awd crx (slowcarguy)
im pretty sure this has been covered before, although i believe it was with crv parts.. i think the only two choices u really have are crv, or a wagovan, although i think crv would be a better choice(newer system). whats the reason you dont want to use crv parts anyways? other than the tiny *** rear axles?
Old Dec 24, 2005 | 12:07 PM
QuarterMileMaster's Avatar
Geez... You are going to get reemed for this one. You need to try the search option before doing your own post, this has been covered like 8 bazillion times. Anyways, to lay it all down for you, It doesn't matter what car you use the parts from (crv or wagovan) the whole rear drivetrain is rediculously weak. How much power are you planning on making?? Because I know that the whole rear assembly can only handle like 140 hp safely otherwise you are looking at replacing: rear output shaft, driveshaft, rear diff., and axels, now if you don't mind custom making most of that and or spending a but load of money on getting them made, quit dreaming. Not to mention, as light as crx's are you would be adding alot of weight with all that extra junk. Additionally, the power ratio is 60f/40r which in all reality almost defeats the purpose. If you want awd, get a subaru or an RL.
88_hatch_ls
Sep 25, 2017 11:16 PM
Ravewolf
13
Jun 6, 2016 06:24 PM
Fook_me_honda
Oct 6, 2006 12:15 AM
complete beginner
Dec 30, 2005 01:26 PM
