Suspension on 94 integra
Old Dec 24, 2005 | 09:28 AM
wreckeddc4's Avatar
Default Suspension on 94 integra
I cant figure out how to adjust the camber on the stock suspension on my 94 integra.The car is not lowered at all, 100% stock but the camber is messed up.If anyone knows how to adjust this please let me know. Thanks.
Old Dec 24, 2005 | 11:58 AM
gt30typer's Avatar
Default Re: Suspension on 94 integra (wreckeddc4)
Your camber is due to something being bent. ie control arms or steering knuckles. You can adjust the rear in the positive direction by adding washers behind the upper control arm. Check your toe settings as well
Old Dec 24, 2005 | 01:43 PM
teg racer 877's Avatar
Default Re: Suspension on 94 integra (gt30typer)
yea you cant adjust the camber on the stock front end of a dc, you got something bent, what are the numbers on the camber? if your under 2 degrees neg. your fine, any pos. camber though and you should look for something bent and replace it.
Custard
Jun 20, 2017 11:37 AM
blainky
May 8, 2013 06:30 PM
HondaCivic2006
Honda Civic (2006 - 2015)
Mar 19, 2009 04:40 AM
Tyson
Dec 1, 2004 03:13 PM
Type R1
Apr 24, 2002 05:14 PM
