Suspension & Brakes Theory, alignment, spring rates....
Suspension on my crx
Old Dec 24, 2005 | 09:23 AM
CarAudioPro's Avatar
Default Suspension on my crx
oksoi have a 90crxw/b16 turbo. right now i have stock suspension. it sucks.i wanted to go with fully adjustable tein setup but its just gonna be to much moola.so i was thinking of doing skunk adjustables with tokiko allumina's. what do you all think?
Old Dec 24, 2005 | 09:41 AM
Default Re: Suspension on my crx (CarAudioPro)
P.S. i am looking for mostly spirited driving on the street and this is my daily driver. but i was thinking about maybe in the future tryingout auto x. and don't want to have to buy 2 suspension setups.
Old Dec 24, 2005 | 11:54 AM
SiRay13's Avatar
Before you start dumping money into springs/shocks make sure you check out your bushings, if your bushings are worn then your suspension is going to suck no matter what kind of shocks and springs you put on. I spent about 220$ and replaced every bushing on my car with polyurethane. The kits you see from energy suspension don't include the trailing arm bushings and a few others, expect some time and hassle to install these but it will be well worth your while.
Old Jan 2, 2006 | 12:19 AM
Default Re: Suspension on my crx (SiRay13)
thanx for the post bro. i wa thinkin about the bushings but herd there a pain to put in, i'll keep it in mind
Old Jan 10, 2006 | 09:56 AM
bspeed's Avatar
You can always go to a junk yard and buy all the control arms etc... for your car, they will probably damn near give them too you. Then put the energy suspension bushings in your "new" pieces... install... go get an alignment.
Way easier than disassembling your car and trying to finish it in one day, food for thought.
Old Jan 10, 2006 | 01:09 PM
Tyson's Avatar
i recommend illuminas. but i dont recommend skunk2s. theyre not a good spring rate, way too stiff, even with extra weight of the engine.
get ground controls if you want adjustable springs. their regular springs will work fine with illuminas.
95excoup
Suspension & Brakes
Aug 14, 2014 02:59 PM
99tegjawn
Suspension & Brakes
Apr 30, 2011 08:31 AM
SVOboy
Aug 22, 2005 04:38 PM
