sputtering and guages going nuts.b18
Old Dec 24, 2005 | 09:09 AM
blockhondab18c5's Avatar
Default sputtering and guages going nuts.b18
Ok I'll be driving along and my speedo will stop working,tach will start jumping around,and starts sputtering.I let off the gas it stops sputtering,or I mash the gas it stops sputtering,but the guages still go crazy.Any ideas?I rebuilt the distibutor and it solved my problem for a few days but its back again.I'm thinking the distibutor coil or ecu.Anybody experience this before?I need to drive this car 1200 miles 3 days from now.
Any and all help apreciated
Old Dec 24, 2005 | 09:29 AM
Redline130's Avatar
Default Re: sputtering and guages going nuts.b18 (blockhondab18c5)
I would suggest changing out either the coil and/or the ignitor and see if that helps your problems.
Old Dec 24, 2005 | 09:47 AM
Thanks man I have a msd coil and cap I'm not using so I am going to try that today and I'll let you know the results
Old Dec 24, 2005 | 10:33 AM
Blaze45's Avatar
Brrraaaap!
Default Re: (blockhondab18c5)
Check all your grounds just in case...
Old Dec 24, 2005 | 12:42 PM
Not the Coil.The car just crapped out all together I now have a unusaly dim check engine light and a solid light onthe ecu (obd0 b16ecu)Anybody have a spare ecu in the Maryland area?
Old Dec 24, 2005 | 01:15 PM
Are there any other ecu's that will work for my car that I won't have to change abunch of ****. crx obd0
b18c5
Old Dec 25, 2005 | 07:27 AM
bump
Old Dec 26, 2005 | 04:11 AM
StorminMatt's Avatar
Default Re: (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Check all your grounds just in case...</TD></TR></TABLE>
Yes, CHECK ALL THE GROUNDS RIGHT AWAY! Problems such as gauges going wild and a constanly lit, but dim check engine light point directly to bad ground(s). Pay particular attention the ground on the thermostat housing and the grounds on the transmission and passenger side frame rail. I suspect something is either broken, corroded, or just loose. In fact, if you have done an engine swap, there is a most excellent chance that you did not properly tighten one of the ground screws.
dvp95
May 14, 2007 04:11 PM
tigueremalo
Jan 23, 2007 06:42 AM
cloin51
Honda Civic (2001 - 2005)
10
Dec 9, 2006 07:13 AM
trooper0641
22
Jan 3, 2004 09:14 PM
Slain
Aug 24, 2002 04:00 PM
