Right turn blinker - works intermittently?
Old Dec 24, 2005 | 07:46 AM
Quik89Si's Avatar
Default Right turn blinker - works intermittently?
My left-turn blinker works fine.
When I push the right turn blinker down 1/2 way (like to change lanes on the fwy) I have to push it forward at the same time to make it work.
When I push it down all the way, it doesn't work at all when it's cold (unless I push it forward) but when it starts to get warmer outside, it will make a "skkkkkkkkkkkk" noise and then finally start to blink, after about 3 seconds of the noise.
Anybody have a clue what I need to fix to make this problem go away? I don't think it's the relay b/c the left blinker works fine. Is it the blinker switch?
Thanks!
Alex
Old Dec 24, 2005 | 10:07 AM
Slow ass EF's Avatar
Default Re: Right turn blinker - works intermittently? (Quik89Si)
turn signal switch is bad
Old Dec 24, 2005 | 10:49 AM
MENACE's Avatar
Default Re: Right turn blinker - works intermittently? (slow *** ef)
IDK man but mine work like that to, Everytime i turn them on, they flash on and off... both sides tho, and the hazzards too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow *** ef &raquo;</TD></TR><TR><TD CLASS="quote">turn signal switch is bad</TD></TR></TABLE>
Really tho, sounds like the switch is just broken. Try getting one from a junkyard, and swappping it out.
Old Dec 24, 2005 | 10:53 AM
SVOboy's Avatar
I have this problem, been too lazy to post and figure out and answer, guess I'll get another switch.
Old Dec 24, 2005 | 06:48 PM
Quik89Si's Avatar
Default Re: (SVOboy)
Junkyard will have to be the way to go, as just that side switch from Honda is like $110...maybe I can take it apart and re-solder something or fix a connection. It looks like its easy enough to remove.
Old Dec 24, 2005 | 06:55 PM
SVOboy's Avatar
Lemme know what you find out, there're two rexes in my yard, but I dunno when I can get out there. If I do go out there soon I'll try to get the other for you though.
Meraut
Mar 11, 2013 06:34 AM
layedoutat0psi
35
Sep 21, 2007 04:48 PM
dreams190
Apr 1, 2005 07:00 AM
Bodman
Mar 18, 2004 04:07 PM
krazyDOHC
27
Aug 18, 2003 04:24 PM
