Intake Manifold Swap Question
Old Dec 23, 2005 | 11:53 PM
pouponu's Avatar
Default Intake Manifold Swap Question
if this is a F.A.Q. I need a link but i have a 95 gsr and theres an idle surge problem im giving up and goin to be replaceing the whole manifold...my buddy gave me a Civic SiR II intake manifold but it doesn't bolt up....what oem intake manifolds will fit my head..im trying to avoid spending a lot of money on a performance one, because if i go performance im gonna want a jun but i really dont wanna spend a grand rite now
Old Dec 24, 2005 | 01:32 AM
blackdelslo's Avatar
Default Re: Intake Manifold Swap Question (pouponu)
uhh did you check all of the vacuum lines? I really doubt that manifold got cracked.
Old Dec 24, 2005 | 07:53 AM
blkb18's Avatar
have you tried another IAC valve yet?
Old Dec 24, 2005 | 08:31 AM
pouponu's Avatar
Default Re: Intake Manifold Swap Question (blkb18)
yea i replaced iac valve twice not sayin with brend new unit but i tried it.......so do you know any compadible manifolds
Old Dec 24, 2005 | 08:46 AM
Sack Master's Avatar
The only factory manifold that will work on a gs-r motor(1994+) is a gsr manifold(1994+).
Old Dec 24, 2005 | 12:13 PM
tegbooster's Avatar
Default Re: Intake Manifold Swap Question (Sack Master)
well put... the bolt pattern on the 94+ gsr is unfortunately unique...i'd suggest going w/ an OEM replacement, they aren't hard to find in the classifieds, honda-acura.net has them as well...shop around...i got my LS manifold for 35 shipped... it will be a good temp replacement
Old Dec 24, 2005 | 04:05 PM
puffsef's Avatar
If its surging then check the fast idle valve under the throttle body Thereshoud be 4 10mm bolts holding this in(cant remember there might be 3)Take the cylindrical thing off and take the 2 screws out of the end of it and screw the white thing down that surrounds the spring loaded nipple in the center.
Integrt
Nov 23, 2009 05:38 AM
PacsterEg6
May 1, 2009 04:17 PM
Touch
Jan 1, 2006 11:07 AM
94gsrvtek19
Oct 5, 2005 06:09 PM
dingusjt
Apr 8, 2003 06:40 AM
