starter or main relay
Old Dec 23, 2005 | 06:58 PM
kgard's Avatar
Default starter or main relay
please don't flame me for this post. I have searched but didn't find anything that would compare the two issues. after taking my daughter to dance class I came out to start my 91 CRX SI and It wouldn't turn over and there was clicking coming from the main relay (little black box above the hood release). I called a friend and after we couldn't get it to turn over he gave me a push and the car started right up and I drove it home. Once I got it home I tried it again and had the same results. THe battery is about 3 months old and the starter about 4 months old. What do you guys think.
THanks for the assistance.
Old Dec 23, 2005 | 07:03 PM
Redline130's Avatar
Default Re: starter or main relay (kgard)
Most likely it's your main relay. However, you were able to kick start it. Check to see if your fuel pump is priming when you turn the key to the on position. If you can't hear a humming sound, then it's the main relay.
Old Dec 24, 2005 | 05:34 AM
driveahonda's Avatar
hey man... 1) if it is your starter then have someone turning the key while you are hitting the starter and solenoid with something metal(like a big wrench or pipe) 2)if it is your starter relay or main relay, a)get an ohm meter and test each relay or b)go find a 88-91 civic/crx in a junk yard and grab the relay(s) out of it.. trim level(si,dx,hf) doesnt matter, they are use the same
Old Jan 8, 2006 | 04:29 PM
DB1_559's Avatar
hey thanks fo the forum cuz my 91 civic hatch is not starting... i dont noe wat the problem is... im not gettin spark and the car still isnt startin... it seems like every time i try to start it... the battery starts drainin... i recharge the battery...still nottin... i thing its the starter relay... hopefully sumone can help me cuz its been frustrating me so bad...
Old Jan 8, 2006 | 08:27 PM
Redline130's Avatar
Default Re: (jdmboi86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 &raquo;</TD></TR><TR><TD CLASS="quote">hey thanks fo the forum cuz my 91 civic hatch is not starting... i dont noe wat the problem is... im not gettin spark and the car still isnt startin... it seems like every time i try to start it... the battery starts drainin... i recharge the battery...still nottin... i thing its the starter relay... hopefully sumone can help me cuz its been frustrating me so bad... </TD></TR></TABLE>
First thing you need to do is find out why you aren't getting any spark. Two things to look at are the coil and ignitor. Usually that is the reason for no spark situations.
Old Jan 8, 2006 | 10:39 PM
DRAMA's Avatar
main relay, easy to fix with solder iron, and check your grounds on your engine & trans.
denraweb
Mar 9, 2014 12:25 PM
jdmunlimited1
Apr 3, 2010 05:47 PM
keviiinnnnn
Jan 2, 2008 07:27 PM
wambus
Feb 12, 2004 03:09 PM
DsCivicEx
Feb 5, 2004 09:16 AM
