will the lsd differential from a b16 tranny work in an ls tranny?
Old Dec 23, 2005 | 03:18 PM
the.hamburglar's Avatar
Default will the lsd differential from a b16 tranny work in an ls tranny?
will it work?
Old Dec 23, 2005 | 07:31 PM
projectTeG's Avatar
depending on the years yes. whats years tranny is the lsd coming from and what year tranny is it going into?
Old Dec 23, 2005 | 09:18 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (projectTeG)
if i can remember right, the final drive's have to match up. (i had the same problem i have a LSD that can fit into a SI tranny) So in that case the only LSD oem that should fit is one from a Y1 or JDM civic/sir (ef8/9). which has the same final (4.266) in the 94+ integra ls/rs/gs.
^^ this talking about me though since i have a LS.
Now i dont know if Hydro and Cable play a role in the LSD working or not, but you can refer to this if you have more questions.
http://www.allmotorhonda.com/t...s.htm
Old Dec 23, 2005 | 10:04 PM
projectTeG's Avatar
Default Re: (00IntegrAllmotoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">if i can remember right, the final drive's have to match up. (i had the same problem i have a LSD that can fit into a SI tranny) So in that case the only LSD oem that should fit is one from a Y1 or JDM civic/sir (ef8/9). which has the same final (4.266) in the 94+ integra ls/rs/gs.
http://www.allmotorhonda.com/t...s.htm</TD></TR></TABLE>
the only cable tranny that cant swap in a new diff is the 90-91...they have different housings. the 92-93 ys1 cable trannys can accept the 94-01 diffs...with work
Old Dec 24, 2005 | 02:25 PM
ok i dont know the years but i have a jdm b16a obd1 with a quaife lsd i put in last summer. so now im planning on getting the b18b motor because the b16 blew and i didnt want the b16 tranny on the ls motor because of the gearing so i was going to take out the lsd from my b16 tranny and put it into the 94-95 ls tranny. make sense?
Old Dec 24, 2005 | 05:00 PM
projectTeG's Avatar
Default Re: (the.hamburglar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">ok i dont know the years but i have a jdm b16a obd1 with a quaife lsd i put in last summer. so now im planning on getting the b18b motor because the b16 blew and i didnt want the b16 tranny on the ls motor because of the gearing so i was going to take out the lsd from my b16 tranny and put it into the 94-95 ls tranny. make sense?</TD></TR></TABLE>
why not just run the b16 tranny? its a great upgrade from the ls tranny.
Old Dec 24, 2005 | 07:41 PM
the gears are too short. in 4th gear ill only hit 94mph at 7000rpm. if i want to break 100mph ill have to shift into 5th
votoms888
May 14, 2007 05:15 PM
teamXteg
Apr 16, 2006 09:28 PM
boosted94teggy
Oct 27, 2005 11:51 AM
Vtecme92
Aug 3, 2005 02:46 PM
NyQuiL
Jun 5, 2003 11:35 AM
