Ticking (searched)
Old Dec 23, 2005 | 12:25 PM
plikit's Avatar
Default Ticking (searched)
I drive an h22a1 just rebuilt about 9k miles ago. I've read that a ticking from the head can be valve related, most likely needing a valve adjustment. Being that the motor was just rebuilt I don't think it needs an adjustment. And I had a small leak coming from the valve cover so I brought it back to the shop to replace the seal and take a look at the valves while they had it open. Turns out the valves are "perfect". What else could be the culprit? It's a very distinctive tick, I can hear it at idle and what ever speed I'm going. It is does get faster as the rpms climb tho. I'm still learning about hondas.. so maybe this ticking is normal?
Old Dec 23, 2005 | 01:17 PM
AzCivic1.6's Avatar
Default Re: Ticking (plikit)
what did they "rebuild"? just because they say replaced say the pistons/ bearings doesn't mean they did anything to the head or did a valve adjustment.
Old Dec 23, 2005 | 01:41 PM
plikit's Avatar
Default Re: Ticking (AzCivic1.6)
they rebuilt everything, engine hydrolocked. rod snapped, blew 2 holes in the block, smashed valves, broke the oil squirters, everything.. they remachined what was salvagable and replaced the rest. they tell me theres nothing wrong with the valves, just trying to find out if there could be any other problems. i'm sure the shop wouldve done there best to find something tho.. more broken stuff means more money for them to fix it.
Old Dec 23, 2005 | 02:03 PM
AzCivic1.6's Avatar
well you could start w/ a valve lash adjustment, its pretty easy, and if that doesn't work move on to something else.
Old Dec 23, 2005 | 03:09 PM
typeS's Avatar
maybe the timing belt tensioner? also most hondas have a slight tick from the valves that is always there. changing the oil frequently helps minimize it though.
Old Dec 23, 2005 | 07:48 PM
93h22a1vtec's Avatar
Default Re: Ticking (typeS)
injectors possibly. Does it increase as u rev?
Old Dec 25, 2005 | 08:28 AM
plikit's Avatar
Default Re: Ticking (93h22a1vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93h22a1vtec &raquo;</TD></TR><TR><TD CLASS="quote">injectors possibly. Does it increase as u rev?</TD></TR></TABLE>
yeah, it does increase in speed as i rev the motor. injectors tick when they're on their way out? i use injector cleaner every few thousand miles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeS &raquo;</TD></TR><TR><TD CLASS="quote">maybe the timing belt tensioner? also most hondas have a slight tick from the valves that is always there. changing the oil frequently helps minimize it though.</TD></TR></TABLE>
yeah, i thought maybe the motor just ticks. i wasnt sure tho. i do change my oil every 3k miles
Old Dec 27, 2005 | 12:36 PM
danerr's Avatar
hey dude, its winter now and when my engine is cold i have a clicking near the cylinder head. turned out it was one of the injectors, you can safely pull the power tab off one of them and see if the clicking stops. i hope i helped
Modified by danerr at 6:32 PM 1/8/2006
Old Dec 27, 2005 | 06:40 PM
bigz187's Avatar
Default Re: (danerr)
lost motion assembly?????? Hopefully not cause then u have to pull the head....try the valve adj. 1st then report back
Old Dec 28, 2005 | 02:55 PM
plikit's Avatar
Default Re: (bigz187)
okay, im starting to think its an injector.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigz187 &raquo;</TD></TR><TR><TD CLASS="quote">lost motion assembly?????? Hopefully not cause then u have to pull the head....try the valve adj. 1st then report back</TD></TR></TABLE>
valves dont need adjusted, shop already looked at them. and whats a motion assembly?
thewrai6th
Jan 20, 2010 05:00 PM
pr3lude1992
Apr 1, 2009 05:33 AM
si937
Jul 25, 2006 02:18 PM
TeamCracka
Feb 17, 2004 06:33 PM
skribblah
Jun 30, 2003 08:10 PM
