need help on crx steering wheel
Old Dec 23, 2005 | 12:17 PM
kantfadedisazn's Avatar
Default need help on crx steering wheel
yeah just wondering how the hell do u take of the steering wheel of a 88 crx hf, cuz i want to put my racing steering wheel if any body can help let me no
Old Dec 23, 2005 | 12:20 PM
03SIHATCH's Avatar
Default Re: need help on crx steering wheel (kantfadedisazn)
Get a flathead screwdriver and gently pry the H in the center of the wheel off. Once that is off youll see the nut that you have to undo. Might take some muscle to break it loose once that comes off just pull the wheel off. And reassemble.
Old Dec 23, 2005 | 12:25 PM
rsca_crx's Avatar
Default Re: need help on crx steering wheel (03SIHATCH)
a white-out/nailpolish/grease marker/whatever reference mark will help keep things straight on reassembly
Old Dec 23, 2005 | 12:29 PM
kulangot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03SIHATCH &raquo;</TD></TR><TR><TD CLASS="quote">Get a flathead screwdriver and gently pry the H in the center of the wheel off. Once that is off youll see the nut that you have to undo. Might take some muscle to break it loose once that comes off just pull the wheel off. And reassemble.</TD></TR></TABLE>
also once you get the H off you can use a 4way the 19mm..i think...
Old Dec 23, 2005 | 08:40 PM
Default Re: need help on crx steering wheel (kulangot)
thanks guys
killercrx91
Jun 21, 2009 07:27 PM
justinw
Oct 16, 2008 11:11 AM
turboITR#704
Jan 8, 2008 12:37 AM
Rob.
13
Aug 5, 2004 07:06 PM
travis
Apr 11, 2002 04:40 PM
