steering wheel shaking while driving not braking
Old Dec 23, 2005 | 11:34 AM
LudeJdm's Avatar
Default steering wheel shaking while driving not braking
when i drive my steering wheel shakes more than usual and pulls to the left....i blew a front left shock would that be the reason why its shaking and pulls??? or is it cuz i havent rotated my tires in a while
Old Dec 23, 2005 | 12:45 PM
Hairy Hudson's Avatar
Default Re: steering wheel shaking while driving not braking (HdA1T6CzH6)
My car was doing that and pissed me off, I just had the tires ballanced and it went away.
Old Dec 23, 2005 | 01:28 PM
Mach69's Avatar
It would be a reason why your car is pulling to the left. As far as shaking, I do not know. Balance your wheels?
Old Dec 23, 2005 | 02:46 PM
LudeJdm's Avatar
Default Re: steering wheel shaking while driving not braking (Mach69)
just lifted up my car and rotated my tires....i looked under.....daym ripped boot...looks like i need a new axle....anyone selling??? are all d-series axles the same??? cuz i have a z6 motor from a 92 civic...wondering if i axles from 92-95 civic the same as the 96-00 ones?????
Old Dec 23, 2005 | 04:15 PM
I don't know, news ones are $100 each at the parts store. When ever I tear a boot I just replace the whole thing its faster and I know the joint is good.
Old Dec 23, 2005 | 04:26 PM
gospeedgo1's Avatar
autozone has axles for around 50.00. they have a core charge, but just bring back your old axle and you are set. lifetime warranty
Old Dec 23, 2005 | 07:02 PM
LudeJdm's Avatar
Default Re: steering wheel shaking while driving not braking (gospeedgo1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gospeedgo1 &raquo;</TD></TR><TR><TD CLASS="quote">autozone has axles for around 50.00. they have a core charge, but just bring back your old axle and you are set. lifetime warranty</TD></TR></TABLE>
which ones? 92-95 or 96-00 axles???
Old Dec 23, 2005 | 07:27 PM
MENACE's Avatar
You probely have a bad tire, any time you have a vibration with a pull, its normally caused by a tire, and most of the time you can just look at the tire ans see the spott that messed up.
Old Dec 23, 2005 | 11:09 PM
classic69's Avatar
Default Re: steering wheel shaking while driving not braking (MENACE)
axles are the same for all d series exceeept the HF axles which have different splines on outer joint
Old Dec 24, 2005 | 09:24 AM
90_crx_si's Avatar
Default Re: steering wheel shaking while driving not braking (classic69)
How can a torn boot cause a vibration?
Old Dec 24, 2005 | 10:03 AM
Slow ass EF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MENACE &raquo;</TD></TR><TR><TD CLASS="quote">You probely have a bad tire, any time you have a vibration with a pull, its normally caused by a tire, and most of the time you can just look at the tire ans see the spott that messed up. </TD></TR></TABLE>
Old Dec 24, 2005 | 10:31 AM
gospeedgo1's Avatar
Default Re: steering wheel shaking while driving not braking (slow *** ef)
i think they all are in the same price range. definitely get lifetime warranty.
Old Dec 24, 2005 | 06:08 PM
EF_338's Avatar
ha thats funny cause my car does the samething and i have a torn boot too
but i have new tires so i know its not the tires
i was think i needed a alignment
Old Dec 24, 2005 | 06:45 PM
Craigp23usa's Avatar
unbalanced tires 4 sure
Old Dec 24, 2005 | 07:07 PM
eeeKs's Avatar
go and balanc e your tires
shaking should go away
Old Dec 24, 2005 | 07:27 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HdA1T6CzH6 &raquo;</TD></TR><TR><TD CLASS="quote">when i drive my steering wheel shakes more than usual and pulls to the left....i blew a front left shock would that be the reason why its shaking and pulls??? or is it cuz i havent rotated my tires in a while</TD></TR></TABLE>
an (extremely) blown shock will cause your car to shake uncontrollably.
Old Dec 24, 2005 | 08:51 PM
d15bturbo's Avatar
Default Re: steering wheel shaking while driving not braking (Tyson)
could be barkes( but might not)
also Rack and pinion
or tires
Old Dec 24, 2005 | 10:41 PM
wushubrian's Avatar
try an alignment.
Old Dec 25, 2005 | 10:54 PM
LudeJdm's Avatar
Default Re: steering wheel shaking while driving not braking (wushubrian)
bad axle a reason???? ripped boot???
Old Dec 25, 2005 | 11:17 PM
a1320honda's Avatar
hey, mines doin the same thing, under acceleration nothing, pulls good and solid, but when i let off it shakes the wheel and pulls left, had the axle rebuilt and still does it. it also doesnt do it all the time, like if its doin it and i turn hard left or right, it will go away.
Old Dec 25, 2005 | 11:36 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
an (extremely) blown shock will cause your car to shake uncontrollably.</TD></TR></TABLE>
Old Dec 25, 2005 | 11:54 PM
crxsi8's Avatar
my car shakes after i did the swap!..
Old Dec 27, 2005 | 07:48 PM
LudeJdm's Avatar
Default Re: (crxsi8)
i had my tires mounted and balanced when i bought them....i just rotated them too....so it could be cuz of the blown shock or alignment????
Old Dec 28, 2005 | 04:25 AM
StorminMatt's Avatar
Default Re: (HdA1T6CzH6)
It could be alignment or a bad shock. But it could also be other things like a bad/loose wheel bearing or even a warped brake disk.
VIS250P
Feb 5, 2007 08:37 AM
pr0phet
Oct 17, 2005 05:28 PM
swiftstyles
Nov 27, 2004 02:38 PM
lithium00
Dec 10, 2003 07:22 PM
shortyz
Mar 29, 2003 03:36 PM
