dual point injection
Im having problems with getting my car started, i am getting spark but When i try starting my car gas will poof out through the throtle body i dont think the injectors are working right i havent seen any gas getting into the engine if anyone knows how to test dual point injection injectors to see if they are spraying i could use the help, or if you have any ideas im all ears
Shoot some starter fluid into the throttle and if it starts, then you know its a fuel prbolem..As far as the smoke coming out of the throttle,, that usually hapens when the valves are opening at the wrong time..Due to the timing being off..Are you getting any codes?
no i havent trtyed starter fluid because when i open up the throtle body i looked in side there and there is just gas sitting in there its like it wont go into the engine
Hellzone-1000
Sep 9, 2015 06:40 PM
jarhead90crx
12
Sep 24, 2011 08:27 AM
notfastenough
11
Sep 5, 2004 01:33 PM
