Sputtering issues
Old Dec 23, 2005 | 06:53 AM
migs's Avatar
Default Sputtering issues
My friend has a 1990 CRX which has a JDM B16A motor in it. He is also using the JDM ECU. Since the day he installed it, he has been getting partial throttle sputtering issues. If the throttle is held at a certain position, the car will "sputter"
We recently changed the fuel pump from the stock Multi Port injection fuel pump to a GSR fuel pump. Car runs much better however the "sputter" is still there under the same circumstances? What can it be?
Old Dec 23, 2005 | 06:59 AM
TommyBB's Avatar
Default Re: Sputtering issues (migs)
Check the timing it might be off a hair. Mine sputtered when I did the timing belt because it was off a little. does it back fire?
Old Dec 23, 2005 | 07:10 AM
migs's Avatar
Default Re: Sputtering issues (TommyBB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TommyBB &raquo;</TD></TR><TR><TD CLASS="quote">Check the timing it might be off a hair. Mine sputtered when I did the timing belt because it was off a little. does it back fire?</TD></TR></TABLE>
Time to time.
Old Dec 23, 2005 | 08:11 AM
TommyBB's Avatar
check the timing because mine was only off a coupld degrees but it made it sputter and stall every once in a blue moon
Old Dec 23, 2005 | 09:12 AM
crx_88_si's Avatar
does he have BOTH o2 sensors installed?
Old Dec 23, 2005 | 09:25 AM
InJ3cted's Avatar
Default Re: (crx_88_si)
make sure there are no vacumn leaks how does it idle?
check timing
adjust tps
Old Dec 23, 2005 | 10:26 PM
migs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">does he have BOTH o2 sensors installed?</TD></TR></TABLE>
As far as I know, just 1.
Idles great actually.
Old Dec 23, 2005 | 11:05 PM
classic69's Avatar
i had symptoms like that when my timing was off
Old Dec 23, 2005 | 11:35 PM
puffsef's Avatar
Check timing/ fuel filter/ fuel pressure regulator etc.....
Old Dec 30, 2005 | 09:12 PM
xxmikexx206's Avatar
I had the same problem with my car... my timing was only off one tooth!!!! i would chech ignition timing also though and for any vacuum leaks, take a can of starting fluid and spray around the intake manifold and any vacuum hoses you can get to, if the idle goes up then you know you have a vacuum leak. this process is easy, fast, and really works!!!!
Old Dec 30, 2005 | 09:40 PM
tallguy's Avatar
not to steal this thread but will the timing belt really cause the car to back fire. because mine back fires ever time i let off the gas.
Old Dec 30, 2005 | 10:51 PM
migs's Avatar
Default Re: Sputtering issues (tallguy)
Ended up being a distributor.
crispins
May 11, 2015 07:50 AM
toolboxtony
Jul 18, 2011 03:23 PM
Briman2021
Jul 22, 2006 08:01 PM
Wayne_Curr
Apr 3, 2006 10:57 PM
Contender25
Jun 9, 2005 07:10 PM
