Change Bulbs in Gauge Cluster ???
Old Dec 23, 2005 | 06:16 AM
Elbowpunk's Avatar
Default Change Bulbs in Gauge Cluster ???
Ight then... I got everything out, execpt the back wires to the gauges it slef, my hand cant fit back there..... ANY WAY i can get it out ????? I dont wanna give up now......
Someone was tellin me about this speed cable... ?? help !
Old Dec 23, 2005 | 06:27 AM
dc2nick's Avatar
Default Re: Change Bulbs in Gauge Cluster ??? (Elbowpunk)
<U>Changing factory guage bulbs....</U>
heres an article....
Old Dec 23, 2005 | 06:32 AM
b62pteg#2's Avatar
Elbow...knowing which gen Integra you have would help...
You mention the speedo cable. If you do in fact have a 2nd gen, disconnect the speedo cable from the tranny end and feed some slack back up towards the cluster. Then pull the cluster out, push the tabs in on the speedo cable on the back of the speedo itself, unattach the cable, and then you should have enough slack to remove the wiring harness connectors (two big grey ones on top, left and right, and if you have cruise, a small green or yellow, i forget which, 1/2 way down, slightly to the left).
Install is reverse of the removal...and don't forget to disconnect your battery
-- Kevin
BTW, if you do have a second gen, make sure to check out this thread on G2IC, and make sure you see my post (a few down from the top, same username as I am on here)
http://www.g2ic.com/forums/showthread.php?t=136233
Old Dec 23, 2005 | 02:10 PM
Elbowpunk's Avatar
Default Re: Change Bulbs in Gauge Cluster ??? (b62pteg#2)
LOL ... um
91 Teg LS (g2) thanks!
peanut butter
Feb 18, 2008 04:00 PM
rkrone
Mar 9, 2006 03:07 PM
cutt
Nov 12, 2004 06:57 PM
loid
Jul 26, 2004 08:33 AM
rasta420
Aug 26, 2002 04:25 PM
