Dynamat in integra question
Old Dec 23, 2005 | 04:50 AM
Silent9o8's Avatar
Default Dynamat in integra question
Hey i have a 96 Integra SE 2 door. I wanna dynamat my trunk would 16SQ be enough? cause i have 4 wedge packs 4 SQ each pack. I get them for like 11 bucks at best buy so ya how many would i need
Old Dec 23, 2005 | 05:02 AM
PrinceAli132's Avatar
Default Re: Dynamat in integra question (Silent9o8)
I would think thats enough, but to make sure just go and measure your trunck.
Ali
Old Dec 23, 2005 | 05:13 AM
raverx3m's Avatar
Default Re: Dynamat in integra question (PrinceAli132)
this is what i did
take a screw driver or whatever metal object and tap around the trunk and see which parts resonate thats the parts u will need to cover (the corners and welding lines are usually strong enuff without any dynamat) but if u got loud exhaust id probably MAT the backwall and then spray the trunk with rubber undercoating i sprayed mine and i fukin love it now i can hear my radio over exhaust now
also dont forget the trunk pannels they rattle too
also look into ur wheelwells if they re shipped or old and got no rubber undercoating on them , clean them good and spray some back on there to keep the road noise down
Old Dec 24, 2005 | 05:55 AM
nObOdy65's Avatar
your mentioning a rubber coating? where do you get this?? so i can spray the rubber coating and then do the dynamat option? i like it!!any other links to this rubber coating?
Old Dec 24, 2005 | 06:09 AM
Default Re: (nObOdy65)
You could get that rubber coating at places that spray bedliners. Its the same thing.
Ali
Old Dec 24, 2005 | 01:50 PM
mike9571's Avatar
Default Re: (PrinceAli132)
You can get rubberized coating at any auto place autozone, etc.
Old Dec 25, 2005 | 04:20 AM
EnjoyTheRideDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silent9o8 &raquo;</TD></TR><TR><TD CLASS="quote">Hey i have a 96 Integra SE 2 door. I wanna dynamat my trunk would 16SQ be enough? cause i have 4 wedge packs 4 SQ each pack. I get them for like 11 bucks at best buy so ya how many would i need</TD></TR></TABLE>
iTS enough to do most of your trunk...I did an Integra at BBY using one door kit and got the major spots of the car.
Old Dec 25, 2005 | 07:41 AM
jomama's Avatar
dude, check out http://www.b-quiet.com/ for their stuff... it's just like, if not better than dynamat and it's a lot cheaper if you buy a lot... 16 squares should be enough... but it really depends on how much sound you want to deaden... on my accord, i used more than 50 equivalent squares and it may have still been not enough... invest in doing a good job... not just one that's "good enough"
Old Dec 27, 2005 | 05:25 AM
raverx3m's Avatar
Default Re: (joso2005a)
trunk bedliner and ruberised underating is lil different,trunk bedlinerdries up more like paint and is less flexible than rubberised undercoating so i'd use rubber coating for the trunk
what i did to my car is have the backwall dynamated almost completely to quiet down the exhaust noise and put strips of dynamat on sides and internal pannels and after that i sprayed whole trunk with rubber coating so it looks one color and doesnt have all them dynamat patchez alova the trunk
but the coating really helped to bring the noise down
Old Dec 27, 2005 | 11:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joso2005a &raquo;</TD></TR><TR><TD CLASS="quote">dude, check out http://www.b-quiet.com/ for their stuff... it's just like, if not better than dynamat and it's a lot cheaper if you buy a lot... 16 squares should be enough... but it really depends on how much sound you want to deaden... on my accord, i used more than 50 equivalent squares and it may have still been not enough... invest in doing a good job... not just one that's "good enough"</TD></TR></TABLE>
If you used 50 equivalent wedge pack squares, thats 200 square feet of sound deadening material you slapped onto your car. I would think thats more than enough. As a matter of fact, maybe the sound wasn't killed as much as you hoped because you added so much more weight and the motor worked harder as a result of it. Now your exhaust got louder due to more demand from the motor?
Old Dec 31, 2005 | 10:51 AM
Shaun's Avatar
does this stuff only come in silver?
Dc2 FrEaK
Apr 17, 2006 10:22 PM
2ndName
Dec 15, 2005 07:21 AM
Loveless
Apr 24, 2003 01:42 AM
JLange
Jun 27, 2002 12:55 PM
