bump bump bump
Old Dec 23, 2005 | 12:06 AM
fastfu's Avatar
Default bump bump bump
im getting fed up with the noise my lude is making :?
i get knocking noise every time i go over even the slightest bump and its driving me made, ive done the shock knock "cure" and cut off 1/4" of the metal sleeves and ive had a garage check the rear bushes and i was told they are in really good condition
what else could it be ?
Old Dec 23, 2005 | 04:43 AM
Honda318dx's Avatar
Default Re: bump bump bump (fastfu)
Front or rear upper balljoints..
Old Dec 23, 2005 | 06:39 AM
The_Sober's Avatar
Default Re: bump bump bump (Honda318dx)
ditto
Old Dec 23, 2005 | 08:31 AM
fastfu's Avatar
Default Re: bump bump bump (The_Sober)
one thing i have noticed is that when there is weight in the back of the car the knocking goes away
Old Dec 23, 2005 | 08:45 AM
Hawkze_2.3's Avatar
I would also suggest checking your swaybar endlinks and mounts. My knock was caused by that camber-arm-thing in the rear hitting the swaybar on both sides and then a broken sway bar mount...
Old Dec 23, 2005 | 08:49 AM
Honda318dx's Avatar
Rear upper control arm balljoints.. its a very common problem.. You have to buy new arms though at 120$+ each.
Sccacivic1997
Jan 6, 2014 01:07 PM
motorpsycho68
Feb 14, 2011 08:01 PM
c4agmaddness
May 28, 2009 09:38 PM
2.7liter
Aug 11, 2007 01:44 PM
snowblind7x
Sep 26, 2005 09:15 PM
