Will this bolt up?
Old Dec 22, 2005 | 09:41 PM
MeatballHB's Avatar
Default Will this bolt up?
I have a 97 Civic CX Hatch, and I want to put a b16a into it. Will everything drop right in, and bolt right up?
This is the motor I'm going to buy:
http://hmotorsonline.com/shop/...30005
Will I need anything extra in order for everything to bolt right up, and fit?
Looking for some info,
-Meatball.
Old Dec 22, 2005 | 10:20 PM
tegasaurus's Avatar
Default Re: Will this bolt up? (MeatballHB)
nub
Old Dec 22, 2005 | 11:01 PM
MeatballHB's Avatar
nub...?
Douche
People come here to learn, not to get flamed.
Modified by MeatballHB at 6:34 PM 12/23/2005
Old Dec 23, 2005 | 02:22 PM
MeatballHB's Avatar
Bump
Old Dec 23, 2005 | 03:57 PM
dohcMONSTER's Avatar
Default Re: (MeatballHB)
probably new axels
shift linkage
to wire your car for vtec
probably a new clutch
new water pump (recommended)
convert your car to OBD 1 or get a harness to plug and play
Old Dec 23, 2005 | 04:44 PM
MeatballHB's Avatar
This comes with everything that I would need, except the water pump...Correct?
Old Dec 23, 2005 | 04:55 PM
bosco500's Avatar
Default Re: Will this bolt up? (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">nub</TD></TR></TABLE>
asshol
Old Dec 23, 2005 | 04:56 PM
bosco500's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeatballHB &raquo;</TD></TR><TR><TD CLASS="quote">This comes with everything that I would need, except the water pump...Correct?</TD></TR></TABLE>
I would call the supplier and ask them. They can probably give you all the info on the motor that you will need.
Old Dec 24, 2005 | 09:34 AM
no it has one already but it is usually a good idea change it while the motor is out
guero2craze
Oct 11, 2008 04:43 AM
Skyhigh07
Oct 3, 2008 07:44 PM
EG Boostin
Feb 24, 2007 01:25 PM
xkhalil333x
Dec 24, 2003 12:49 PM
Vinceg99
31
Jun 21, 2003 09:43 PM
