Custom Fuel Rail
ok my buddy's dad owns a machine shop...so my buddy came up with the idea of making some custom fuel rails instead of buying one....well i tryed to post the pics of it but it didn't work...to make a long story short it hold 3 times the fuel that an AEM fuel rail holds and we can make to fit any honda or any car i guess...plus we can sell them for like 50 to 75 bucks cheaper then AEM....i just thought i would throw the idea out there and see if any one was really interested in them....i will have the pics soon...and when i get the pics i would like to let every one know that if you have some ideas on how to make it better let me know...
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowDCtwo »</TD></TR><TR><TD CLASS="quote">ok my buddy's dad owns a machine shop...</TD></TR></TABLE>
Does anyone think it is odd that a back-woods machine shop would have the equipment needed to anodize aluminum?
Im not interested or anything, I just wanted to say anodizing aluminum is extremely easy. I have seen guys do it in their home garage in 5 gallon buckets. Its not difficult at all.
Kyle
Kyle
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy »</TD></TR><TR><TD CLASS="quote">Well, I should research that. I would anodize my cylinder head and intake manifold if it were that easy.</TD></TR></TABLE>
It is. Theres a site I found searching through Google a while back that goes through step-by-step instructions on how to do it and I think the guy even sells DIY kits.
Does anyone think it is odd that a back-woods machine shop would have the equipment needed to anodize aluminum?</TD></TR></TABLE>
what the expletive are you calling back woods machine shop? if u dont like the products we make, put down your allen wrenches for one...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr »</TD></TR><TR><TD CLASS="quote">youll have to purchased sponsorship on the site to even make a post like this sorry.
arent necessarily trying to sell, just get opinions... i do understand where you are coming from though... slowdctwo and i arent a company or anything...
</TD></TR></TABLE>arent necessarily trying to sell, just get opinions... i do understand where you are coming from though... slowdctwo and i arent a company or anything...
its cool. you dont have to have a company to want to sell stuff, and making thin gs to sell is against TOS w/out sponsorship...
so you should be like "how does this look"
instead of "plus we plan to sell them etc..."
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr »</TD></TR><TR><TD CLASS="quote">its cool. you dont have to have a company to want to sell stuff, and making thin gs to sell is against TOS w/out sponsorship...
instead of "plus we plan to sell them etc..."</TD></TR></TABLE>
gotcha... weird thing is no one has said anything to me... eh, we'll see how it goes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 »</TD></TR><TR><TD CLASS="quote">
if u dont like the products we make, put down your allen wrenches for one...</TD></TR></TABLE>
I may be a little slow... But what does that mean? Put down my allen wrenches?
I may be a little slow... But what does that mean? Put down my allen wrenches?</TD></TR></TABLE>
we make allen wrenches, laser sight housings, hubble space telescope parts, surgical devices, pella window products, motorcycle parts, nano somethin or other microscope parts etc. we are NOT a backyard machine shop whatever the expletive that means. we use matsuras, citizens, haas lathes. this isnt ur grandpas garage with a drill and some sheetmetal. 7500 square feet of precision engineering and machining.
woot.
woot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supercreed2002 »</TD></TR><TR><TD CLASS="quote">I like to see the step-by-step DIY powdercoating....link?</TD></TR></TABLE>power coating or anodizing? power coating is cake walk compaired to anodizing becasue you have to make the alumium surface look almost perfect to get a good outcome... with podwer coating you just clean everything up, scuff the surface and then attach a grounding strap to teh part your working on and coat it... then bake it for ~30min depending on the powder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 »</TD></TR><TR><TD CLASS="quote">its anodized... and we send it out to do... they have a huge shop with tanks of acid and such....</TD></TR></TABLE>
Wish I knew of a place cheap enough, and close enough to send them out to....
Sorry, I didn't mean to assume wrong. It's just when you said "my buddy's dad owns a shop", I just assumed it was a hole-in-the-wall shop. Most big shops are corporations not owned by a single private owner.
As a few others have stated anodizing is really a pretty easy process if you are just coloring a few parts. However hard anodizing is a bit more complex. Iam sure if you do enough searching on the web you can find lots of info on setting up a small anodizing setup. The basics that you would need are some sort of tank to hold the chemicals the size really depends on what your anodizing, lead plates or sheets, a good 12v battery charger, some solid aluminum heavy guage wire about the thickness of a coat hanger, battery die electric fluid and a large pot with the anodizing dye. By the way if you do enough searching you can usually find companys that will give you free samples of the dye
