Anyone on here using this b-series motor mount kit?
Just wanted to know if these motor mounts have fit pretty well as far as axle, hood and motor position/alignment. They're sold here on h-tech, here's the link, B18TurboEF sells them: https://honda-tech.com/zerothread?id=1432601
well i havent used those although i watched my boy swap a motor for some1 with those without issues, except the driver side bracket needs to use bolts instead of the factory studs on a DC chassis.
anyway ive personally used Hasport and Avid mounts and i can say with certainty...
Hasport =
Avid =
(the provided bolts dont fit correctly go figure)
Hasport =
Avid =
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redasphalt »</TD></TR><TR><TD CLASS="quote">i got my mounts from jdmshit for 175 shipped... try them out </TD></TR></TABLE>
How are those hcp mounts anyway?? How low is the motor..? and how is the vibration?
HCP
Motor position is perfect. Vibration is present but not excessive, but I don't really care about it. They line up perfectly.
Good to hear, anyone else? I actually already bought some from (above) and it appears that the driver's side portion of the motor sits lower than I expected. However, I still haven't bolted up the rear mount yet, so I guess I see what happens afterwards. I'm still working on fabricating an a/c bracket, so after that gets done I'll have all the mounts bolted up. Hopefully it won't be an issue.
I don't know if those are the same as streetimports. But to me, the pictures looks the same. I bought mine from Streetimports and working great on my b16, nothing to complaint about, no vibrant or anything. I don't felt anything at all, it's pretty smooth. To me and my knowledge of using them, it's best and worth the money. I used it's for a year now, and nothing happened. Honestly, it's felt much better than my other friend who has a hcp mount kit on his car.
I don't know how low but I can closed my hook and nothing happened just like my old stock motor. For the price and quality, I would recommend to my friends. I guess for the price being cheap probably it's not as brigher or colorfull as Hassport or Avid....just pure black...but who care...it's working great on mine!
Just thought I'd update...Mounts work very well, motor position is great and I've had no problems at all. If you do plan on buying these it's helpful to have some spare honda hardware (nuts, bolts, washers etc.) for the mounts or else you might need to make a trip to the store. Btw,
to B18TurboEf, great seller, responded very quickly to any questions I had.
Black R
Jun 16, 2002 08:55 PM
