What the hell brakes did I have!??!
Old Dec 22, 2005 | 06:55 PM
ne3ek's Avatar
Default What the hell brakes did I have!??!
Ok so here's the deal.
I bought a molested 90 crx si. I was doing the front brakes yesterday I went to autozone and got some duralast gold pads and rotors (can't complain i didn't expect to keep civic brakes too long anyways)
Now lemme tell you when i first got the car the brakes were great! The pedal was very touchy and it stopped awesome I just had warped rotors and the pads were low
So I get these pads and rotors for a 90 crx si and the pads don't fit! So I got some calipers/caliper brackets from some spare 91 cvici si hubs my buddy had in his garage and they were indeed different! I put the new pads and rotors on and holy crap do these brakes suck.. the rotors are great they don't shimmy at all but I have to stomp the **** out of the pedal to slow down from high speeds! BEfore my brakes would lock the tires no problem! These I couldn't lock the tires up.
So basically I want to know what other calipers fit a dx/si hub? The calipers and brackets were different the calipers from the civic si used a 12mm bolt to hold them in.. these other calipers used a 14mm bolt. The rotors were the same just the pads were different. I wan't to put these back on though! They are way better than the civic si calipers and 13s still fit over them!!
Old Dec 22, 2005 | 08:00 PM
ne3ek's Avatar
Default Re: What the hell brakes did I have!??! (ne3ek)
help please (:
Old Dec 22, 2005 | 08:10 PM
Jonathan_ED3's Avatar
It would help if you would tell us what the stamping on the calipers is.
Or maybe you just didn't bleed the new calipers thoroughly.
BTW, CRX Si uses a different fromt caliper from the Civic Si.
Old Dec 22, 2005 | 08:26 PM
ne3ek's Avatar
Default Re: (Jonathan_ED3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 &raquo;</TD></TR><TR><TD CLASS="quote">It would help if you would tell us what the stamping on the calipers is.
I'll try to get the stamping info.. but I have the calipers at a buddy's house.
I ordered the pads for a 90 crx si and used 91 civic si calipers/brackets they were the same.
I don't think I had 90 crx si calipers. I bled the brakes very well, the pedal doesn't go down far at all, it's just very stiff. i have to push very hard to lock them up.
Old Dec 22, 2005 | 08:58 PM
I Want An Si's Avatar
i would try 90 teg brakes/rotors
shwepes
Suspension & Brakes
Jan 23, 2016 06:17 PM
Singlecam4dr
Feb 20, 2007 04:41 PM
skimeast1982
Oct 18, 2006 04:31 AM
EK9 BEEZLER
Jul 25, 2005 04:44 AM
nerdish
Jul 9, 2001 11:54 AM
