Tranny Problems??
Old Mar 17, 2002 | 06:50 PM
phatintegra's Avatar
Default Tranny Problems??
hey, i think im havin tranny problems. It seems like its gettin harder and harder to get into gear. It still goes into gear fine, but it seems as if its gettin "choppy" going into gear, like its not as smooth as it was. i changed the tranny fluid and it didnt help any. I have 120k miles on a stock clutch and the throw out bearing is goin so im puttin in a exedy racing clutch. could this problem have anyting to do with the clutch, the reason i think it doesnt is because its always like that even when the car is off, when my foot is on the clutch or not. should i have the tranny checked out when i get the clutch in??? what could it be?? i hope its not expensive im runnin low on resources!!
Old Mar 18, 2002 | 03:50 AM
madslackin's Avatar
Default Re: Tranny Problems?? (phatintegra)
Could easily just be a clutch problem man. If the clutch is really worn or isn't fully engaging, you bet you could get some choppiness going into all gears.
Typically, if a transmission problem consists of trouble or harshness going into EVERY gear then the chance of the transmission itself being bad is very slight. Check the clutch and clutch cable (if cable clutch) or clutch master/slave cylinder (if hydro clutch).
Justin
Old Mar 18, 2002 | 06:35 AM
Kamin's Avatar
Default Re: Tranny Problems?? (madslackin)
could be the clutch. i would replace that and start from there
if it still happens replace the fluid with redline MTF or honda MTF and see how it goes. you might want to flush the transmission when you change the fluid. (get a flush kit from checker, etc)
good luck
Old Mar 18, 2002 | 11:45 AM
Default Re: Tranny Problems?? (KAMiN)
ttt
Old Mar 19, 2002 | 05:44 AM
how much would it be to get the tranny fixed??????
Old Mar 19, 2002 | 08:02 AM
integra81's Avatar
New User
Old Mar 19, 2002 | 09:09 AM
earl's Avatar
If it's a cable tranny, check your adjustment before you spend any money
Old Mar 19, 2002 | 12:03 PM
speedillusion's Avatar
New User
get your tranny checked, before buying the clutch. just my 02 cents. and you said it's still hard to get in gear even if your foot is off the pedal and the engine is off. then there's a good possibility it's your tranny.
Old Mar 20, 2002 | 05:55 AM
Default Re: Tranny Problems?? (midnitekreeper)
its a tranny of a 94 integra ls how much will it be to fix it or get a new one??
Old Mar 20, 2002 | 12:02 PM
New User
it's cheaper on your pocket to get one off an engine shop (a rebuilt one). you'll pay more for a new tranny or to get the tranny assembly fixed. anyways, it costs more if they replace it for you.
Old Mar 20, 2002 | 04:32 PM
what kind of engine shops are gunna have the tranny i need?? i live on longisland, ny in suffolk??
Old Mar 21, 2002 | 06:57 AM
New User
do a search on some shops around your area. i'm not familiar of the east. i'm sure something will come up.
Old Mar 21, 2002 | 07:56 AM
would u recomend gettin one of those or rebuilding mine??
Old Mar 21, 2002 | 08:46 AM
New User
get one fully rebuilt, you'd have to be really inclined, mechanically or ASE certified. plus think about labor costs. if you have a friend who has experience on trannies, that'll be better. like i said, i'm not sure if it's your tranny, it just sounds like your tranny's doing more work than the engine does. check for cylinder compression too(compression test).
mawkiemarc
Aug 1, 2005 08:41 PM
reeder321
12
Dec 31, 2003 07:29 AM
phatintegra
Mar 21, 2002 06:39 PM
phatintegra
Mar 20, 2002 05:35 PM
phatintegra
Mar 20, 2002 04:33 PM
