disassembling '90 Si seats
Old Dec 22, 2005 | 02:10 PM
Malgerus's Avatar
Default disassembling '90 Si seats
I'm trying to take apart my 1990 Si seats to fix the broken headrests. I ripped apart an 88 seat before to see how the head rests were mounted, and I know that my Si seats need to have that little bracket in there welded. However, I'm having trouble getting the cloth off the top part of the seat.
The plastic tab that the headreset slides into seems to be in the way. How do I remove this, and how do I get the seat apart without mangling it? I've already taken off the metal clips at the bottom, and can access the foam through there.
Here's a pic:
Old Dec 22, 2005 | 02:51 PM
DaNnYsEvEn's Avatar
Default Re: disassembling '90 Si seats (Mr. S)
it should just pull over it. thats how i took out mine. you gottta play with it a bit, but be very careful it doesnt rip
Old Dec 22, 2005 | 02:52 PM
Malgerus's Avatar
Default Re: disassembling '90 Si seats (DaNnYsEvEn)
Really? It seems like it just doesn't have enough play to go over that plastic tab.
Old Dec 22, 2005 | 02:54 PM
DaNnYsEvEn's Avatar
it should. that part is the same as my accord seats so it should just pull over and out. i was stumped at first but after fighting with it. i was able to get it out. carefully
Old Dec 22, 2005 | 03:11 PM
Malgerus's Avatar
The fabric only has enough room for the two shafts to go through; it won't slip around the whole plastic unit without cutting it. There seems to be some sort of stud holding the plastic to the metal, but it has no nut on it...
Old Dec 22, 2005 | 03:32 PM
Malgerus's Avatar
Turns out there's a screw holding the plastic bit on, underneath the release. The bad news is that I think I damaged the release a bit
I'll post my progress later.
Old Dec 22, 2005 | 03:43 PM
DaNnYsEvEn's Avatar
maybe this will give you an idea? im not sure if youve seen this or not but here just in case.
Old Dec 22, 2005 | 03:44 PM
DaNnYsEvEn's Avatar
i know that part is different but maybe this will give you an idea
Old Dec 24, 2005 | 12:48 PM
Malgerus's Avatar
Thanks for the pic!
Turns out you have to take off the tab that controls the movement of the headrest, and there's a screw underneath. This must be undone or the fabric will not come off.
I ended up fixing my seat. The headrest bracket was simply bent, not destroyed or anything. I have the passenger side done! Next up is the driver side
Old Dec 24, 2005 | 01:04 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaNnYsEvEn &raquo;</TD></TR><TR><TD CLASS="quote">maybe this will give you an idea? im not sure if youve seen this or not but here just in case.
Thats a CRX Si/DX seat. The original poster has a Civic Si seat, which is completely different.
Old Dec 28, 2005 | 10:11 AM
Malgerus's Avatar
Default Re: disassembling '90 Si seats (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Thats a CRX Si/DX seat. The original poster has a Civic Si seat, which is completely different.</TD></TR></TABLE>
Yup. Here's a pic for the search archives:
You can see how the bottom part of the headrest bracket was bent backwards, so that the plastic clip and the headrest shafts could not go through the metal support. I simply pounded the bottom of the bracket forward, and the top part of it down. This is the passenger seat. The driver's side was even worse, but I managed to fix it in about an hour and a half thanks (while watching TV) thanks to practice
thevtecnician
Honda Civic (2006 - 2015)
Aug 26, 2017 04:29 PM
B16-CRX
Northeast (Sales)
Jun 6, 2010 08:26 PM
8VEYBEYB
Jul 24, 2009 08:32 PM
Malgerus
Nov 23, 2003 03:14 PM
MisterB
May 21, 2002 11:24 PM
