Edelbrock Intake Mani vs ITR manifold
Old Dec 22, 2005 | 12:44 PM
SpeedingHatch's Avatar
Default Edelbrock Intake Mani vs ITR manifold
My setup is basically a piston and rod b16 with GSR cams. Right now I have an ITR intake manifold, but Im looking to squeeze out some more power and was curious if the Edelbrock would be worth it over the ITR.
Ive searched but Ive only seen high HP cars comment (450+). I plan on running 18psi or so on an sc34, trying to get in the 375 range.
Thoughts, comments?
Thanks
Old Dec 22, 2005 | 07:43 PM
Default Re: Edelbrock Intake Mani vs ITR manifold (SpeedingHatch)
Old Dec 22, 2005 | 09:38 PM
turbo*s2k's Avatar
If those are your hp goals I would stick with what you have. The Edelbrock manifold will help but your okay for now.
Good luck with your setup.
Old Dec 22, 2005 | 10:00 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
Default Re: Edelbrock Intake Mani vs ITR manifold (TurboChrgd_Civic)
what he said <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic &raquo;</TD></TR><TR><TD CLASS="quote">If those are your hp goals I would stick with what you have. The Edelbrock manifold will help but your okay for now.
Good luck with your setup.</TD></TR></TABLE>
Old Dec 22, 2005 | 10:09 PM
thanks guys
Stick-e-rice
Feb 7, 2008 03:28 PM
klungemonger
Jul 11, 2007 03:05 PM
All Motor Speed
May 5, 2003 07:11 PM
EFing8
Oct 27, 2002 04:48 PM
DynamiteSJ
Oct 12, 2002 10:20 PM
