CHECK OIL LIGHT
Old Dec 22, 2005 | 07:15 AM
RIPPO's Avatar
Default CHECK OIL LIGHT
can someone explain why it is that my check oil light always flashes on whenever i start the car. it will stay on for more than a brief second like all the others. even after i've added oil and even after i've gotten my oil changes, it still shows up. maybe it's kuz the vegas weather is so damn cold. kuz im use to LA i dunno please help guys thanks
Old Dec 22, 2005 | 07:19 AM
Everyones Hero's Avatar
Default Re: CHECK OIL LIGHT (RIPPO)
Do you know where the sensor is on the car?
It's above and to the right of the oil filter. Check it to make sure the plug that goes onto the back of it is on tight.
It may be a bad sensor or a bad connection.
Old Dec 22, 2005 | 07:21 AM
AutoXer's Avatar
Default Re: CHECK OIL LIGHT (Everyones Hero)
It's not an oil level light, it's an oil pressure light. Most likely this happens when the pump goes bad. Adding oil isn't going to have any effect on the pressure, unless there's none in the pan at all.
Old Dec 22, 2005 | 07:22 AM
EJ1 wilcox's Avatar
Hmmm...
Could be your oil pump.
Do you have an oil pressure gauge? It not, you might want to hook one up for a bit and make sure your oil pump is making enough pressure.
Oil pumps are pretty durable, but if the sensor is okay and you have plenty of oil, I don't know what else it would be.
*edit*
AutoXer beat me to it!
Old Dec 22, 2005 | 07:25 AM
RIPPO's Avatar
Default Re: CHECK OIL LIGHT (EJ1 wilcox)
koo thanks for the info fellas. ima take a look at it today
itzyaboyzeem03
Jul 1, 2016 04:40 PM
boost4life1
Jan 26, 2013 06:27 PM
young geezer
Oct 13, 2011 07:07 PM
joker4096
May 2, 2010 08:27 PM
Roi
22
Nov 17, 2005 10:01 PM
