GSR cluster into 93 civic coupe
Old Dec 22, 2005 | 07:09 AM
5thgencivicr's Avatar
Default GSR cluster into 93 civic coupe
i found all the diy's on this and i just found myself a gs cluster. i want to do this swap this weekend. the only thing i wanna know is .....are all the guages that need to work funcional. like is the speedo and tac accurate? is the fuel guage accurate? the teg holds more fuel so is the gsr cluster guage off when put into a civic? and what about the temp? i know i can do this but nothing ever ben said on how qaccurate the guages are. so let me know. thanks guys. its not worth it to me if the guages arent functional.
Old Dec 22, 2005 | 10:10 AM
Relic1's Avatar
mine works perfectly. No inaccuracy that I can tell. And I'm picky.
Old Dec 22, 2005 | 10:37 AM
Default Re: (Relic1)
thanks. i just hope i can get min to look as stock as possible. i hate the gaps they usually have.
Old Dec 22, 2005 | 10:40 AM
Default Re: (5thgencivicr)
also do u have any pics of yours. i have seen all the diy pics but i want to see more. thanks.
Old Dec 22, 2005 | 10:41 AM
jbs's Avatar
jbs
Default Re: GSR cluster into 93 civic coupe (5thgencivicr)
It is accurate. The reading are all from the same senders. ie fuel, temp etc. . . . as long as you have a perfectly working guage it should give you accurate readings.
Old Dec 22, 2005 | 10:48 AM
mrchaos's Avatar
Default Re: GSR cluster into 93 civic coupe (jbs)
The only thing that maybe off is the speedo. The one from the Integra will be calibrated for 185/65R14 tires I believe.
Old Dec 22, 2005 | 10:55 AM
jbs's Avatar
jbs
Old Dec 22, 2005 | 11:16 AM
eg6hatch94's Avatar
my friend put a whole gsr interior swap in his eg6. looks decent. im more into jdm.
Old Dec 22, 2005 | 11:21 AM
fmrprojects's Avatar
Default Re: (jbs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbs &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
thats clean
Old Dec 22, 2005 | 11:30 AM
SOHC4life 96's Avatar
Default Re: (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">thats clean</TD></TR></TABLE>
Took the words right out of my mouth.
Old Dec 22, 2005 | 12:20 PM
ej_jnice's Avatar
Default Re: GSR cluster into 93 civic coupe (eg6hatch94)
u might as well go ahead and put a whole gsr dash in its looks clean in a eg
Old Dec 22, 2005 | 01:40 PM
Default Re: GSR cluster into 93 civic coupe (ej_jnice)
nah to much work. i think just the cluster is great. and damn that is one clean install. since the cluster for the teg gos up to 140mph and the civic stops at 120 mph....does that mean that when my civic going 40 the tegs cluster will read 60? or am i thinking like an idiot? i want everything to be as accurate as possible. how hard was it to get your cluster to look that clean? thats one of the best i have seen.
Old Dec 22, 2005 | 01:41 PM
also i ride on 17's during the summer. so theat should screw with my speedo too. i just dont want it to be wwwaaayyyy off.
Old Dec 22, 2005 | 01:43 PM
does anyone know if its easier and look cleaner if you somehow use the eg cluster clea plastic piece? or is it uglier? i havent found a answer for this. wireing is simple the biggest thing thats gonna **** me off is getting it to look clean/stock. im a nit pick.
Old Dec 22, 2005 | 05:09 PM
bump
Old Dec 22, 2005 | 05:14 PM
mrchaos's Avatar
use a tire size calculator to figure out how much you will be off by.
i like this one... http://www.1010tires.com/TireSizeCalculator.asp
Old Dec 22, 2005 | 05:17 PM
Default Re: GSR cluster into 93 civic coupe (mrchaos)
well my civics wheels are 14's but i drive around with 17's and its not off much. so i shouldnt reallly notice much of a differance.im just saying i hope when im going 20 it doesnt say 40 on the teg cluster.
Old Dec 22, 2005 | 06:33 PM
mrchaos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivicr &raquo;</TD></TR><TR><TD CLASS="quote">well my civics wheels are 14's but i drive around with 17's and its not off much. so i shouldnt reallly notice much of a differance.im just saying i hope when im going 20 it doesnt say 40 on the teg cluster.</TD></TR></TABLE>
that it will not....
Old Dec 22, 2005 | 06:47 PM
thanks everyone for the help.
Old Dec 22, 2005 | 08:26 PM
Hybrid96EK's Avatar
Its just as accurate as any other stock Honda cluster from what I have seen..
Old Dec 22, 2005 | 08:37 PM
E.Honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej_jnice &raquo;</TD></TR><TR><TD CLASS="quote">u might as well go ahead and put a whole gsr dash in its looks clean in a eg</TD></TR></TABLE>
It looks like ****. I have yet to see anyone make the door panels look good. You get gaps at the doors. Not too mention the hours and hours of work.
Old Dec 22, 2005 | 08:38 PM
E.Honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivicr &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know if its easier and look cleaner if you somehow use the eg cluster clea plastic piece? or is it uglier? i havent found a answer for this. wireing is simple the biggest thing thats gonna **** me off is getting it to look clean/stock. im a nit pick. </TD></TR></TABLE>
If you are worried about it looking stock......LEAVE IT ALONE.
Old Dec 24, 2005 | 07:19 PM
man how the expletive do u cut this thing to fit? no one on here has detailed that. i cant get it to look right for the life of me.
Old Dec 24, 2005 | 09:09 PM
JDM_EjONE's Avatar
do u have to mod it does the gsr cluster just bolt up?????
Old Dec 24, 2005 | 09:24 PM
E.Honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivicr &raquo;</TD></TR><TR><TD CLASS="quote">man how the expletive do u cut this thing to fit? no one on here has detailed that. i cant get it to look right for the life of me.</TD></TR></TABLE>
LOL I told u 2 leave it alone.
