Question about using 450 dsms
Old Dec 22, 2005 | 05:04 AM
Ak_ef9's Avatar
Default Question about using 450 dsms
I have a set of 450 Dsms with about 20,000 miles on them and was wondering if it is too much for my setup. I am currently running a B18a1 and I have so far done 3 angle valve job, ported head, stage 3 crower cams, skunk2 titanium valve spring w/ retainers, rev racing valves, CTR pistons, eagle rods, ACT 8.8 flywheel, Full MSD ignition, DC Sports 4-2-1 header, hondata S200, B16 hydro tranny, Individual throttle bodies, 255lph fuel pump, Aem fuel rail and FPR, NGK iridium spark plugs. Everything still need to be put together but I am just waiting on a clutch and the alaskan weather. If you have any info on this pm me or reply or send me an e-mail at aksnowrider2004@yahoo.com
Old Dec 22, 2005 | 05:06 AM
CRX Toad's Avatar
Default Re: Question about using 450 dsms (Ak_ef9)
This questions is going to get a better response in the all motor forum. Just a thought for you.
Old Dec 22, 2005 | 05:11 AM
crxnj's Avatar
Default Re: Question about using 450 dsms (CRX Toad)
They are overkill but you have the hondata so you can control them..Just dont raise the fuel pressure with that aem fpr..You should have a pretty low duty cycle
Old Dec 22, 2005 | 05:16 AM
Ak_ef9's Avatar
Default Re: Question about using 450 dsms (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">They are overkill but you have the hondata so you can control them..Just dont raise the fuel pressure with that aem fpr..You should have a pretty low duty cycle </TD></TR></TABLE>
Thank you for the info
Th3savinday
Apr 4, 2007 06:24 PM
bigz187
Mar 19, 2006 06:28 PM
allmotorek8
12
Sep 5, 2005 01:00 AM
BlackOut21
Jul 8, 2005 01:33 PM
