compression ratio
Old Dec 22, 2005 | 12:26 AM
Ruben19's Avatar
Default compression ratio
how high of compression can i go with my stock ecu
im planing to build a b20 cr vtec
i want to do 85.5mm pistons or 86mm
i will probably use the b16a2 head or b18c1 head
i was thinking 11:5 to 12:5 ratio
Old Dec 22, 2005 | 01:28 AM
fmrprojects's Avatar
Default Re: compression ratio (Ruben19)
u cant run a stock ecu with that set-up. it will run wat lean. look into hondata, chip your ecu, chrome, uberdata. you will need bigger injectors too
Old Dec 22, 2005 | 01:53 AM
Juggernaut 2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 &raquo;</TD></TR><TR><TD CLASS="quote">how high of compression can i go with my stock ecu
i was thinking 11:5 to 12:5 ratio</TD></TR></TABLE>
Damn why so large?
Old Dec 22, 2005 | 02:27 AM
UncleD's Avatar
Default Re: compression ratio (Juggernaut 2)
Also if you plan on doing 86, you're gonna be re-shaping your combustion chambers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote"> it will run wat lean. </TD></TR></TABLE>
And what sense does this make?
Teamdiesel
10
Sep 29, 2007 02:36 PM
careawholelot
Sep 11, 2005 12:06 PM
CALM_AS_A_BOMB
Mar 14, 2005 05:34 AM
Matgallis
Jun 8, 2004 10:20 PM
B20vtec86crx
Feb 5, 2004 06:49 PM
