fuel
My car breaks a lot!
ok i have a 99 civic si with all the air upgrades i can get....but i think i need to add more fuel...im not sure what i need to get, fuel rail, injectors, fuel pump, fuel pressure reg, fuel filter.
like what will give me hp gains...and what are useless....what size injectors...i have a N/A setup...but im thinking that im going to go turbo sooner or later
if you could help me out that would be awsome
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">Does it run okay?
A wideband O2 sensor is probably a good idea first. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamvirus »</TD></TR><TR><TD CLASS="quote">ok i have a 99 civic si with all the air upgrades i can get....but i think i need to add more fuel...im not sure what i need to get, fuel rail, injectors, fuel pump, fuel pressure reg, fuel filter.
if you could help me out that would be awsome</TD></TR></TABLE>
decide what route your going to take first. If you go turbo it will have an influence on every purchase you make.
If you're going to do that then just leave it alone till you decide to actually add the turbo. You're never gonna get back what you paid for all the NA stuff you are/gonna buy. Just start saving your money for the turbo build. You're gonna need as much money as you can possibly get to get it tuned.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamvirus »</TD></TR><TR><TD CLASS="quote">well, im N/A but in the future im going to switch to turbo</TD></TR></TABLE>
So you dont have all the "air" mods like you said you did.
You don't need bigger injectors unless you are turbo or have very agressive cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamvirus »</TD></TR><TR><TD CLASS="quote">ok...sounds good
y do people upgrade fuel rails and get pressure regualtors and stuff?</TD></TR></TABLE>
For better fuel flow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamvirus »</TD></TR><TR><TD CLASS="quote">so is it pointless to upgrade them? or you think its worth it to invest the money</TD></TR></TABLE>
Only if you need more fuel. With your setup I would say that you don't need them.
