00 ITR Cams = CTR cams?
Old Mar 17, 2002 | 05:36 PM
Hard2Find's Avatar
Default 00 ITR Cams = CTR cams?
i heard that the 00 ITR Cams are equivalent to CTR cams. same aggressiveness and power...is this true?
Old Mar 17, 2002 | 05:39 PM
Reid's Avatar
Global Moderator
Default Re: 00 ITR Cams = CTR cams? (Hard2Find)
Search reveals:
https://honda-tech.com/zerothread?id=94803
Old Mar 17, 2002 | 05:40 PM
chad's Avatar
Moderator
the 99-00 itr cams are almost exactly what CTR cams are.... .3 more duration on the CTR...not exact on the differences...but for the price you can't beat the itr's over the ctr for little to no gains
Old Mar 17, 2002 | 05:48 PM
FAST4DR's Avatar
Default Re: 00 ITR Cams = CTR cams? (Chad)
01 ITR = CTR...click the thread above to see...
Old Mar 18, 2002 | 01:00 AM
Ch33se's Avatar
New User
Default Re: 00 ITR Cams = CTR cams? (FAST4DR)
does that mean the 2000 itr cams are the same as 2001? therefore the 2000 is also ctr cams?
Old Mar 18, 2002 | 04:40 AM
IN VTEC's Avatar
I'm still scratching my head over how that test conclusively says that CTR cams = 00/01 ITR cams, and that 00/01 ITR cams do not = 97-99 ITR cams.
What's that cutout made of? And, wouldn't it be susceptible to deformation, or at least enough to not be able to tell the difference between a few degrees? Even if it wasn't deformable (let's imaginatively assume that cutout was billet aluminum), how readily able is the human eye able to distinguish between a few degrees (3 in this case)?
The test is unbiased, but I'm not sure how precise it is.
WackyRicanMan
Dec 22, 2014 01:56 PM
SilverEK96
Apr 24, 2012 08:52 AM
dj-bilbo
Feb 13, 2010 06:16 AM
kenepo_vtec
Jul 4, 2004 08:57 PM
