JDM h22 question.
Old Dec 21, 2005 | 10:01 PM
IOSUA's Avatar
Default JDM h22 question.
ok i have a jdm h22a with a h23a block. runs fine but when i let go of the gas, the idel drops really low like it wasnt to die, the oil sign flashes a little bit then the car goes back to normal. i changed my IACV, MAP, and TPS. what else could it be? im running a stock p13 obd1. anyone know? help!
Old Dec 22, 2005 | 05:26 AM
Sabbotage's Avatar
Default Re: JDM h22 question. (jdm dc2 01)
did you replace your IACV with a new or a used one? reason i ask is that my car was doin the exact same thing and thats what it was. I just cleaned mine with some brake parts cleaner. probably not the best way but it worked. Also, did you set your voltage correctly on your TPS?
Old Dec 23, 2005 | 02:28 PM
IOSUA's Avatar
Default Re: JDM h22 question. (Sabbotage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sabbotage &raquo;</TD></TR><TR><TD CLASS="quote">did you replace your IACV with a new or a used one? reason i ask is that my car was doin the exact same thing and thats what it was. I just cleaned mine with some brake parts cleaner. probably not the best way but it worked. Also, did you set your voltage correctly on your TPS? </TD></TR></TABLE>
i changed me IACV and cleaned it with break part cleaner too. how do set the volatge on the TPS? and what is it suppose t o be set at?
Old Dec 23, 2005 | 03:12 PM
mach3lude's Avatar
the tps is suppose to be set at .5 volts. just loosen the 2 screws in the back and turn it just like you would on a distributor and get as close as you can to .5 volts.
Old Dec 23, 2005 | 08:25 PM
lak8's Avatar
i had the same problem. check this link for a fix
https://honda-tech.com/zerothread?id=1392751
Old Dec 24, 2005 | 05:43 PM
IOSUA's Avatar
cool thanks for the info everyone. i hope this works.
Old Dec 24, 2005 | 06:18 PM
veganej's Avatar
Default Re: (jdm dc2 01)
i had and still have the same problem, but mine is more with fuel, i pinched my fuel line and it runs fine. i think its the difference of obd1 injectors, obd2 motor, etc. i dunno.
Old Dec 24, 2005 | 09:07 PM
IOSUA's Avatar
Default Re: (veganstraightedge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veganstraightedge &raquo;</TD></TR><TR><TD CLASS="quote">i had and still have the same problem, but mine is more with fuel, i pinched my fuel line and it runs fine. i think its the difference of obd1 injectors, obd2 motor, etc. i dunno.</TD></TR></TABLE>
i have a 01 integra (OBD2) i have a OBD1 jumper harness with a stock h22 ecu. my motor is obd1. does anyone know whats the stock psi on fuel for the h22? i have a fuel pressure regulator on with a gauge. i just need to know that, maybe thats my problem.????
Old Dec 30, 2005 | 01:16 PM
IOSUA's Avatar
bump. help!
Adam.
Nov 28, 2006 01:39 PM
GOTNOS
Mar 2, 2004 10:50 AM
jiggy
Nov 8, 2003 07:59 AM
