Weird vibrating steering wheel need help !
Ok ... so my steering wheel is vibrating like a fucken vibrater after i hit 60mph it only happens when i'm not accelerating or braking. it has a slightly noticable vibration below 60mph doing the same thing but its onlly really noticable after 60.
Other things to be known:
Car has 50k miles.
Front two tires are newer than rear two.
Curbed it a while back nothing to seriouse.
Have had 2 alignments and balanced so its not an alignment or balancing issue.
what could it be guys .. i'm thinking maybe some part of the suspension is bent slightly or maybe a bushing wore out either in suspension or motor mount. or could it be that one of my struts is going.
Car has 50k miles.
well if its not when your accelerating or braking its not a motor mount. so it pretty much just does it when youre coasting?
be super careful i had 2 blowouts with other friends when this was happening-check the inside sidewall of all of your tires for wear- there is something uneven either in your suspension or axles it might be causing something to rub therfore causing a blowout....or two- keep posted
tipically when your steering wheel wobbles like that your wheel is either out of balance or poss one of you front tires is low on air check thouse options out before anything else
perhaps:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip b18b »</TD></TR><TR><TD CLASS="quote"> wheel is out of balance </TD></TR></TABLE>
rodondoaccord
Nov 21, 2015 06:31 AM
91_Civic_Hatch
Sep 22, 2008 06:33 PM
