h22 vtec wiring for eg
Old Dec 21, 2005 | 08:19 PM
beaneg6's Avatar
Default h22 vtec wiring for eg
is there any difference in vtec wiring for a eg w/ a h22 compared to a eg w/ a ls/vtec?
Old Dec 21, 2005 | 08:20 PM
tdo's Avatar
tdo
Default Re: h22 vtec wiring for eg (beaneg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 &raquo;</TD></TR><TR><TD CLASS="quote">is there any difference in vtec wiring for a eg w/ a h22 compared to a eg w/ a ls/vtec?</TD></TR></TABLE>
dont think so. as long as its the same OBD.
Old Dec 21, 2005 | 08:23 PM
beaneg6's Avatar
Default Re: h22 vtec wiring for eg (tdo)
obd1....there are no different pinouts needed?
Old Dec 21, 2005 | 08:53 PM
tdo's Avatar
tdo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 &raquo;</TD></TR><TR><TD CLASS="quote">obd1....there are no different pinouts needed?</TD></TR></TABLE>
should be the same.
the wiring harness should be extended for the h22 thats about it.
edit- i got a h22 and i was running on a P13 now im running a P28 and it runs fine. i didnt have to change any wires.
Old Dec 21, 2005 | 09:15 PM
beaneg6's Avatar
did u find that running a p13 was better than a p28? i also have check engine light for #9 any help??
Old Dec 22, 2005 | 06:18 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 &raquo;</TD></TR><TR><TD CLASS="quote">did u find that running a p13 was better than a p28?</TD></TR></TABLE>
that just depends on what fuel maps are on the p28 if its chipped. If its not chipped, then a p13 would be a lot better. vtec wires are the same as a ls-vtec would be. With a p13, the vtec pressure switch ground goes to A26, with a p28, you can just ground that wire anywhere on the chassis/head.
Old Dec 22, 2005 | 03:06 PM
tdo's Avatar
tdo
Default Re: h22 vtec wiring for eg (IHateJDM)
i have a h22 base map on the P28 and i wired it for the IAB's. only thing i dont have is the knock sensor and egr stuff.
i think its a lot better. I dont have to deal with all that egr stuff and now my engine bay looks a lot cleaner without all the vacuum hoses from the egr.
btw code 9 is crank angle sensor.
Old Dec 22, 2005 | 08:42 PM
beaneg6's Avatar
thanks tdo for the help is it possible for you to chip me a h22 basemap? my ecu is chipped right now to my knowledge it is mugen? but what would you recommend? pm me or answer here
Old Dec 22, 2005 | 11:22 PM
tdo's Avatar
tdo
sure, ill put a stock H22 base map on it for you. Thats what im running on mines.
Old Dec 23, 2005 | 04:17 PM
beaneg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdo &raquo;</TD></TR><TR><TD CLASS="quote">sure, ill put a stock H22 base map on it for you. Thats what im running on mines.</TD></TR></TABLE>
pm me a contact number i also have a homie that might want his ecu chipped!!!
blindh22
Sep 5, 2006 03:09 AM
jaydmegsix
Nov 13, 2004 05:35 PM
boostedprelude
Jul 31, 2004 08:31 AM
juicy.koreans.suck
11
Feb 27, 2003 05:34 PM
