Megan 4-1 Header with an Omni Power Test Pipe. Which pipe style to get?
Old Dec 21, 2005 | 05:16 PM
Tippyman's Avatar
Default Megan 4-1 Header with an Omni Power Test Pipe. Which pipe style to get?
I'm getting this header:
And I'm getting this test pipe:
Should I get the JDM spec test pipe or the USDM spec test pipe?
Old Dec 21, 2005 | 05:19 PM
WhoDoYouThink's Avatar
Default Re: Megan 4-1 Header with an Omni Power Test Pipe. Which pipe style to get? (Tippyman98)
jdm will fit it, 2.5". usdm is 2.25"
Old Dec 21, 2005 | 05:30 PM
Tippyman's Avatar
So what do I need to bolt the header up to the test pipe? Any adapters, flanges, etc...
Old Dec 21, 2005 | 06:53 PM
Tippyman's Avatar
bump. anyone know if it will just bolt up, or will it rtequire something special?
Old Dec 21, 2005 | 07:04 PM
xEnderx's Avatar
Default Re: (Tippyman98)
Should bolt right up....but you'll need to get the test pipe to match the size of the collector on yoru header. Personally I wouldn't spend money on a header that didn't have a 2.5 collector.
Old Dec 21, 2005 | 07:06 PM
Tippyman's Avatar
hey, u're da one who convinced me to get this test pipe! (i changed header selection though!) Ya, it's got a 2.5 inch collector. so it should bolt up to da 2.5 inch jdm omni pipe right?
Old Dec 21, 2005 | 07:22 PM
djtony5's Avatar
Yes you are correct sir. Be sure to get a complete 2.5 custom exhaust to compliment the header and test pipe.
Old Dec 21, 2005 | 07:30 PM
Tippyman's Avatar
i'm actually thinking a Apexi WS so it isn't too loud. (It's 60 mm, so it matches the exit port of the test pipe.)
driveby4082
Sep 14, 2011 03:15 PM
DC2_2
Nov 25, 2006 09:36 PM
the soL that could
Mar 14, 2006 09:12 AM
Shaka01
Feb 26, 2006 11:56 AM
