Problem with Momo Steering Wheel Installation
I need your help H-T'ers. Got a Momo Tuner Steering wheel and an Ek hub for my 99 hatch. I took out the stock steering wheel with out any problems (this is not the first time). I put the new Tuner in and screw in the bolt, turned the wheel, but it's a very stiff turn, and my wheel does NOT turn, only a little bit at a time as I turn the steering wheel more and more.
I double and triple check everything, but I don't know what's causing the problem. I put the stock steering wheel back on and everything is fine, wheels turn, no stiffness or anything.
Anyone with the same problem? BTW, I searched...did not help.
Appreciate your help guys!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LBCek9 »</TD></TR><TR><TD CLASS="quote">I need your help H-T'ers. Got a Momo Tuner Steering wheel and an Ek hub for my 99 hatch. I took out the stock steering wheel with out any problems (this is not the first time). I put the new Tuner in and screw in the bolt, turned the wheel, but it's a very stiff turn, and my wheel does NOT turn, only a little bit at a time as I turn the steering wheel more and more.
Appreciate your help guys!!!</TD></TR></TABLE>
Perhaps you should take some pics of the hub and wheel installed. I've never experienced a problem with aftermarket wheel / hub combinations in any car... *pondering*
are you sure you got the right hub for your car?? If you can get pics that would make it easier for us to understand the problem
