Integra big brake upgrade for CRX
I bought a pair of integra calipers and went to check against the crx and found them to be identical.I then matched them to my 94 integra racecar and found them to be the same size -rotor ,piston,caliper.
Does any one out there know what integra brakes are bigger what size rotor ,piston size .I dont want type R ,cause then you have the 5 lug deal.
any help
Thanks
Marc
any help
Thanks
Marc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o1marc »</TD></TR><TR><TD CLASS="quote">I bought a pair of integra calipers and went to check against the crx and found them to be identical.I then matched them to my 94 integra racecar and found them to be the same size -rotor ,piston,caliper.</TD></TR></TABLE>
Are you sure about that? All USDM '88-91 CRXes had a 9.5" or smaller rotor, while all '90-01 Integras (except Type-R) had a 10.3" front rotor. If your CRX has 10.3" fronts, then someone has already done some sort of brake upgrade to it.
o1marc
13
May 28, 2008 10:02 AM
