Problem with removing axle from half shaft
Old Dec 21, 2005 | 10:59 AM
Cheeech's Avatar
Default Problem with removing axle from half shaft
Can anyone tell me how to remove th axle from the half shaft....i tried for like a half hour or so trying to get to come loose but no luck...and also in the second pic is a half shaft from a LS integ on the buttom and the half shaft that came of my car on top....can anyone tell me what half shaft this is off of? i was thinking of using the LS shaft so i know what axles to get.
thanks
Mike
Old Dec 21, 2005 | 11:15 AM
Cheeech's Avatar
ANyone?
Old Dec 21, 2005 | 11:29 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (CheechJDM)
The shaft that came with my friend's swap gave me hell..
We never did get it to come apart and ended up finding another.
[I think it was in an accident on that side..]
I tried using a "come-along" type winch and busted the cable..
I hooked it to a pole in the parking lot and tried jerking it with a forklift..
The pole moved,but the shaft/axle never came apart..
Old Dec 21, 2005 | 11:41 AM
CRXb18Turbo's Avatar
Default Re: (88DXCRX)
there are marking on the halfshaft.
And use a pry bar. It should pop out easy
Old Dec 21, 2005 | 12:01 PM
Chase's Avatar
Default Re: (CRXb18Turbo)
dude this happened to me. Its rusted in there. I got lucky and there was a axle rebuilder nearby.
First he put some grease(same as the CV boot grease) in/around the area where the axle goes in the halfshaft. He clamped the half shaft tight as **** with a big table top vise, then used a pointy hammer type thing and just started banging with a big hammer. FINALLY it came out.
When i put it all back in i sprayed alot of wd-40 in the halfshaft and then filled it up with the CV grease hah.
Man i got so pissed at that ****......
Old Dec 21, 2005 | 01:17 PM
Cheeech's Avatar
lol yea im getting pissed at this piece of steel called the half (gives me more headaches then my g/f) Shaft, and ill see if i can take it to a shop and have them remove it....gotta do this **** before christmas all my cousins with there tite *** cars are coming over and i dont want my car on jack stands while they are here cuz they will talk ****...lol ********
Old Dec 21, 2005 | 01:49 PM
lightcrx's Avatar
get a hammer and hit it, it should only take like 3 hits.
Old Dec 21, 2005 | 01:50 PM
lightcrx's Avatar
bottom half shaft looks like its from a 90-93, and the other looks like its from a 94+.
Old Dec 21, 2005 | 11:49 PM
Cheeech's Avatar
Default Re: (lightcrx)
ill try tomorrow see if it works
Old Dec 22, 2005 | 05:21 AM
b18CrxSi91's Avatar
71.179.86.205
Same thing happend to me, luckily I had a spare laying around.
Anyone tried torching it? Thats on my list of to do's, might work?
Old Dec 22, 2005 | 05:47 AM
Sgt_Ox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx &raquo;</TD></TR><TR><TD CLASS="quote">get a hammer and hit it, it should only take like 3 hits.</TD></TR></TABLE>dang it's scientifically down to 3 strikes.
Actually that works for me too. But I have pried it with either a chisel or a thick flat tip screwdriver.
Old Dec 22, 2005 | 10:08 AM
Cheeech's Avatar
Default Re: (Sgt_Ox)
no luck so far....ive took alittle break from this nightmare... also, the shalf that still has the axle in it..someone said its from a 94+ integ....is this true cuz i need to know what axle to get at autozone...thanks
Old Dec 22, 2005 | 11:45 AM
Cheeech's Avatar
Default Re: Problem with removing axle from half shaft (CheechJDM)
Ok i FINALLY got this **** out after an hour of pounding the **** out of it BUT i think something bad happened.....correct me if im wrong but isnt the axle supposed to go INTO the shaft not the shaft going into the axle?
Old Dec 22, 2005 | 11:53 AM
JapJunkie's Avatar
yup the axle supposed to poke it like a man!
Old Dec 22, 2005 | 11:56 AM
Cheeech's Avatar
Default Re: Problem with removing axle from half shaft (JapJunkie)
i went and pounded out the end part of the axle from the 90 integ shaft...and that came out like it should so thats a relief now i can use that shaft...and get my car back on the road!! thanks for ur help everyone
Chase's Avatar
well it looks like its supposed to do that?? weird, mine was the opposite. I had a female halfshaft
Old Dec 22, 2005 | 12:06 PM
Cheeech's Avatar
Default Re: Problem with removing axle from half shaft (EF8kid)
or my half shaft just had a sex change...
Old Dec 22, 2005 | 02:59 PM
lightcrx's Avatar
they change between years
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx &raquo;</TD></TR><TR><TD CLASS="quote">bottom half shaft looks like its from a 90-93, and the other looks like its from a 94+.</TD></TR></TABLE>
-joseph
Old Dec 22, 2005 | 03:09 PM
89s1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8kid &raquo;</TD></TR><TR><TD CLASS="quote">well it looks like its supposed to do that?? weird, mine was the opposite. I had a female halfshaft </TD></TR></TABLE>
i also had a female halfshaft, well, i had both, but needed the female one for the axles i got
Old Dec 22, 2005 | 03:45 PM
Sgt_Ox's Avatar
I believe pre-94 intermediate shafts came with the female input and 94+ came with the male end.
Someone will correct me if I'm wrong. But the female intermediate shaft is normally found on the 1st gen B16 and DA Tegs.
Old Dec 22, 2005 | 05:55 PM
Cheeech's Avatar
Default Re: Problem with removing axle from half shaft (Sgt_Ox)
good to know
LuckyJDM
10
Feb 2, 2014 08:01 AM
B_Swapped93
Oct 28, 2013 01:38 AM
MUGEN_EG95
Jun 17, 2009 03:42 PM
DTS
Oct 6, 2006 08:11 AM
90hbvtec
Oct 28, 2003 06:10 AM
