Question about ARP Head studs and Main studs for a B17
Old Dec 21, 2005 | 07:03 AM
IQ's Avatar
IQ
Default Question about ARP Head studs and Main studs for a B17
I am now very confused after reading several posts about the head studs and main studs for the buildup I'm trying to complete.
The setup is going to be a PR3 ITR head bolted to the B17 Block.
I understand that the head is the same PR3 head as the original B17. The head studs posted on the ARP website has a set up for both the B18C1 (208-4303) and one for the B16 (208-4601). I am assuming that the B16 (208-4601) is the right application for my build. Being that I am using the B17 block and the PR3 head.
As for the main studs, I run into the same dilema. ARP has a set listed for the B18C1 (208-5403) and a set for the B16 (208-5402). Again, I assume that the B16 (208-5402) is the proper application for the build as the B17 block is being used.
If anyone has some input, moreso fact then opinion, it would be greatly appreciated.
Confused = Me
Old Dec 21, 2005 | 12:22 PM
IQ's Avatar
IQ
Default Re: Question about ARP Head studs and Main studs for a B17 (IQ)
bump for the gurus
Old Dec 21, 2005 | 06:59 PM
b17integra's Avatar
the application you is for the b16. go with the 8mm rod bolts. and g et the head studs for the b16. b16 block and the b17 are exactly the same. the difference are in the internals..
Old Dec 21, 2005 | 10:04 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Question about ARP Head studs and Main studs for a B17 (b17integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b17integra &raquo;</TD></TR><TR><TD CLASS="quote">the application you is for the b16. go with the 8mm rod bolts. and g et the head studs for the b16. b16 block and the b17 are exactly the same. the difference are in the internals..</TD></TR></TABLE>
Um, no you want the 9mm rodbolts, stock are more than sufficient. Order the head and main studs for a b16a
Old Dec 22, 2005 | 06:47 AM
IQ's Avatar
IQ
Default Re: Question about ARP Head studs and Main studs for a B17 (PURPLETERROR aka BIGMATT)
Thank you sirs!
Very helpful info.
Old Dec 22, 2005 | 06:53 AM
slofu's Avatar
the head studs/bolts are different because, since the b18 blocks are taller, the studs sit lower, and so need to be a bit longer.
the 6 center main studs are different for the b18c to accomodate the bearing brace ('girdle').
i'd also go with the 9mm rod bolts.
00CivicSi5spd
Nov 16, 2015 06:57 PM
DC2.KILLA
Apr 16, 2011 06:43 AM
ripperbone
Jun 11, 2006 07:09 PM
