Suspension & Brakes Theory, alignment, spring rates....
Motor Support Bar...?
Old Dec 21, 2005 | 12:45 AM
Oregon's Avatar
* B A N N E D *
Default Motor Support Bar...?
were can i Buy 1 or 2 of these ?
Any help would be Great
Old Dec 21, 2005 | 06:02 AM
The Weather Man's Avatar
Damn. I've never seen that. Is that some kind of dampner? Thats pretty sexy. Bet it'll work also - man.....bump bump bump
Old Dec 21, 2005 | 06:05 AM
evochuck's Avatar
Default Re: Motor Support Bar...? (Oregon)
its called an engine damper, ingals and NRG sells em
Old Dec 21, 2005 | 10:58 AM
Oregon's Avatar
* B A N N E D *
Default Re: Motor Support Bar...? (evochuck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evochuck &raquo;</TD></TR><TR><TD CLASS="quote">its called an engine damper, ingals and NRG sells em</TD></TR></TABLE>
Ill look into that, thanks
Old Dec 21, 2005 | 12:24 PM
jdmstylesi's Avatar
j's racing, ingalls, NRG all make them
check out http://www.robearracing.com for more info..
Old Dec 21, 2005 | 01:53 PM
archmage's Avatar
Yea I've seen these before but I have no first-hand experience with them.
Do these things really reduce wheel-hop?
How about transmission of vibration and such?
Or actually ---&gt; anyone offer a rundown of the benefits / disadvantages ?
Old Dec 21, 2005 | 05:03 PM
delspool's Avatar
it helps slow the engine shifting on a launch which inreturn helps cut down wheel hop
Old Dec 21, 2005 | 07:25 PM
boosted94cx's Avatar
* B A N N E D *
why not just get better mounts? or make that a solid piece instead of a "damper"?
Old Dec 21, 2005 | 08:02 PM
.water's Avatar
alex jdm bing. it suppose to give you more TQ.rofl by less moving engine movement.
Old Dec 22, 2005 | 04:32 PM
shortyz21's Avatar
Default Re: (s13-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s13-t &raquo;</TD></TR><TR><TD CLASS="quote">why not just get better mounts? or make that a solid piece instead of a "damper"?
most guys scrap that piece of **** because it fails after a half year
then they make a solid one
Old Dec 22, 2005 | 05:04 PM
Oregon's Avatar
* B A N N E D *
Default Re: (shortyz21)
Less Engine movement = more WHP to the ground
Old Dec 23, 2005 | 10:23 AM
Mike D's Avatar
Default Re: (Oregon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oregon &raquo;</TD></TR><TR><TD CLASS="quote">Less Engine movement = more WHP to the ground </TD></TR></TABLE>
show me a dyno where you can actually measure more who from an engine damper.
Ill save you some time. You can't.
Old Dec 23, 2005 | 11:26 AM
Oregon's Avatar
* B A N N E D *
Default Re: (Mike D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike D &raquo;</TD></TR><TR><TD CLASS="quote">show me a dyno where you can actually measure more who from an engine damper.
Ill save you some time. You can't.</TD></TR></TABLE>
Your a Idiot Holy ****
Old Dec 24, 2005 | 01:18 PM
Mike D's Avatar
Your a Idiot Holy **** </TD></TR></TABLE>
why?
Old Dec 24, 2005 | 01:20 PM
EK4civichatch's Avatar
why?</TD></TR></TABLE>
x2
Old Dec 24, 2005 | 11:33 PM
chrisw85's Avatar
You're an idiot, holy ****.
Grammar people, grammar.
Old Dec 25, 2005 | 03:35 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (chrisw85)
I've read on here in a couple of different threads where people where seeing their engine damper failing after awhile.
Old Dec 25, 2005 | 08:38 PM
HamiltonRex's Avatar
Old Dec 26, 2005 | 12:24 AM
Oregon's Avatar
* B A N N E D *
Default Re: (EK4civichatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK4civichatch &raquo;</TD></TR><TR><TD CLASS="quote">
x2</TD></TR></TABLE>
Because i sayd Less engine movement=more power to the ground,
And his comment was pretty much saying i was "lieing" or " dont know what im talkin about "
Eveyone knows less motor movement= more power to the ground,Doesnt matter much im just gonna make my own from DOM pipe and 1/4 heim joint's
Old Dec 26, 2005 | 01:23 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oregon &raquo;</TD></TR><TR><TD CLASS="quote">Because i sayd Less engine movement=more power to the ground,
Eveyone knows less motor movement= more power to the ground,Doesnt matter much im just gonna make my own from DOM pipe and 1/4 heim joint's</TD></TR></TABLE>
less movement odent mean more power to the ground. i get what your saying though. it helps utilize the power the engine already puts out to the ground better. i was thinking about buyng on until i looked at the way its mounted and figured that those little brackets that the damper mounts to wont beable to take the abuse from the engine long. basically they'll bend
Old Dec 26, 2005 | 08:54 PM
TurboLaxx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oregon &raquo;</TD></TR><TR><TD CLASS="quote">were can i Buy 1 or 2 of these ?
Any help would be Great</TD></TR></TABLE>
Why do you want this?? You dont even know WTF this is! Such a ricer. "Oh pretty...me want...what does it do?" Just go spend your money on a bigger wing.
Old Dec 26, 2005 | 09:28 PM
Default Re: Motor Support Bar...? (TurboLaxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboLaxx &raquo;</TD></TR><TR><TD CLASS="quote">Why do you want this?? You dont even know WTF this is! Such a ricer. "Oh pretty...me want...what does it do?" Just go spend your money on a bigger wing.</TD></TR></TABLE>
i agree. A solid engine mount/s would yield better results
Old Dec 27, 2005 | 08:28 AM
Mike D's Avatar
my comment was saying show me a dyno sheet proving your statement, and i said you couldnt, because you cant.
Making comments like you did is misleading. People will then think that if they get these POS engine dampers, they will be making more power, which they wont.
The gain is so minimal, it coldnt be measured on a dyno.
Thats what i meant.
Old Dec 27, 2005 | 09:41 AM
Oregon's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike D &raquo;</TD></TR><TR><TD CLASS="quote">my comment was saying show me a dyno sheet proving your statement, and i said you couldnt, because you cant.
Thats what i meant.</TD></TR></TABLE>
WTF is your prob man ? Have you ever been to the track ? or are you just a forum reader
God your a ******* Retard I dont need a Dyno, Anyone who races 1/4 or knows about racing will tell you, less engine movement = more hp to the ground, Better launch,Less wheel hop,Better0-60ft
And if you cant understand that, You will fail at life.....
Old Dec 27, 2005 | 09:44 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
God your a ******* Retard I dont need a Dyno, Everyone how races 1/4 or knows about racing will tell you, less engine movement = more hp to the ground, and if you cant understand that, You will fail at life.....</TD></TR></TABLE>
...for teh win!
