92 civic random bogging, low idle, won't heat up
Old Dec 20, 2005 | 09:13 PM
hobbz's Avatar
Default 92 civic random bogging, low idle, won't heat up
I am helping a freind with his 92 civic. He bought it from an old lady that said all it needed was a starter.
We replaced the starter. Then we were throwing a code for fuel delivery system.
We replaced the fuel filter, plugs, wires, oil and filter, air filter, o2 sensor. Finally after all of this we thought we had it fixed. Everything was working normal. We never drove it, but under no load all was normal.
Then he got insurance and tags for the car and started driving it. Well the idle went back down to about 300rpm, and in random placed in the power band it sputters and bogs very bad. So bad that going up a slight incline with it floored it will not gain any speed, no matter what gear you are in.
Also most of the time while driving it, it will not heat up, but it it is sitting still the gauge will go to normal temp. as soon as you strat driving it will start to fall back down though.
We have checked for vacum leaks and there are none.
Anyone have any thoughts???
Please help. What sensor could cause this? Anything fuelwise that would cause this?
Oh yeah, i did search
Old Dec 20, 2005 | 09:28 PM
littleredcivic's Avatar
check for a clogged exhaust system. disconnect the exhaust between the exhaust manifold and cat. if the car drives great with just the exhaust manifold, then you have a clogged cat or something else down the line. you may have a water pump that needs replacement, or a thermostat that is not closing which would cause the cars temperature to fluxuate like you describe. it would also be wise to check ignition timing and your spark gap, dist cap and rotor and injector firing pattern.
Old Dec 20, 2005 | 09:30 PM
hobbz's Avatar
Default Re: (littleredcivic)
there is no cat. the old lady's son got ahold of the car. plugs were checked when we put them in less than a week ago. Cap and rotor both visually look good too.
Old Dec 20, 2005 | 09:47 PM
civic_driver's Avatar
If coolant by-pass was done I would undo it and that should fix the temperature issue especially in colder climates.
Old Dec 20, 2005 | 09:49 PM
time for a compression test, cam timing check, ignition timing check, valve lash check.
Old Dec 21, 2005 | 05:51 AM
bloodyknuckles's Avatar
here is a lil more info on the car. i dont know if it will help or not, but its worth a try. oh its my car by the way.
sometimes the car will find the right combination or rpm and throttle pressure/fuel that it will run good. the engine in the those few moments feels strong (as strong as a d15 can anyhow). the car seems to do better when im light on the throttle. it doesnt stutter as much. it accelerates smoothly then and will cruise at a steady speed nicely then as well. but any change in throttle pedal pressure will cause it to stutter and bog again. if i try to accelerate moderate to fast it bog and strutters horribly until higher rpms. the point where it stops bogging will vary, sometimes 3k sometime 4k sometimes 5k.
we will check the timing tomarrow.
thanks guys
Old Dec 21, 2005 | 03:02 PM
check tps, map, o2 sensor outputs. check ignition condition with meters.
b20acura
Aug 14, 2011 07:17 PM
wanderinglost
Nov 7, 2008 08:31 AM
HondaJack
Oct 24, 2006 12:17 PM
TeknoGroover
Dec 3, 2004 04:03 AM
DEVIN22CBR
May 5, 2003 04:09 AM
