will these fit my car?
The rear shocks are different.
I forget the dimensions but fork on the bottom is wider apart on one of the two models.
This has been covered. You can search for a further explanation.
"sup",
the rear lower control arms on the 96-00 civic are thinner than the eg civic/integra. you can run washers to fill in the space in between the fork on the integra/civic eg shock. ive done it on a costumers car that insisted on it. his car rode just fine. or change rear lower control arms. the front is the same.
All you have to do is run some washers/spacers in the rear. When you buy tokico shocks for that car they give you the same as the 92-95 stuff but with spacers. It works fine.
sluggishEG
Suspension & Brakes
Dec 29, 2006 09:04 PM
real_slow_EM1
Nov 8, 2004 01:54 PM
soHybridized
Mar 1, 2002 04:22 AM
