swap for si motor
Old Mar 17, 2002 | 02:07 PM
Rob!'s Avatar
Default swap for si motor
i have a 91 hf and the motor is blown and i picked up a si motor for cheap...will everything bolt up perfect with no problems at all? i am keeping trans and all that? anything i should know before i do this swap?
Old Mar 17, 2002 | 02:13 PM
88civic's Avatar
Default Re: swap for si motor (RaceFacer)
i have a civic 4 dr and want to do the samething. i have the motor and trans and ecu.
Old Mar 17, 2002 | 02:54 PM
CRX7's Avatar
Default Re: swap for si motor (88civic)
The only thing which is somewhat involved is the DPFI to MPFI conversion. I just did this with my B16a swap and I was crossing my fingers when I tried to start it. Distributor plugs are sometimes different as well (mine were). Otherwise I assume that the block and head of an Si and a Dx engine are the exact same so everything should bolt up.
Old Mar 17, 2002 | 03:32 PM
wronghand's Avatar
Default Re: swap for si motor (CRX7)
The HF is already MPFI. Should be plug and play.
Old Mar 17, 2002 | 04:57 PM
CRX7's Avatar
Default Re: swap for si motor (wronghand)
whoops I was wrong, disregard my entire post
[Modified by CRX7, 1:57 AM 3/18/2002]
Old Mar 17, 2002 | 06:27 PM
4gvtec's Avatar
yes your in there! si in hf yes,plug in play.change the intake and ecu from hf to si simple swap!
enve55
31
Oct 16, 2005 05:32 AM
Catch 22
Jun 11, 2004 07:15 AM
crxSoldado
May 3, 2004 08:25 PM
hybridcrx
11
May 27, 2002 05:06 PM
REXvtecSI
Apr 3, 2002 04:37 PM
