h22a in 92 lude
Old Dec 20, 2005 | 05:54 PM
delirious1520's Avatar
Default h22a in 92 lude
Hey guys, I just dropped in the h22a with a buddy and i have fuel and spark and have the plug wires right. But i dont have to exhaust manifold hooked up to the downpipe yet because the h22a manifold doesnt bolt to my h23 downpipe... My problem is the motor turns over fine and backfires but wont run. Could it be from no back pressure, i thoguth it would atleast run. Any input would be great
Old Dec 20, 2005 | 05:57 PM
SteveoBA8's Avatar
Default Re: h22a in 92 lude (delirious1520)
most likely, wait
Old Dec 20, 2005 | 06:21 PM
Default Re: h22a in 92 lude (SteveoBA8)
If its not the exhaust, does anyone have any suggestions, any sensors?
Old Dec 20, 2005 | 07:56 PM
H23 Power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delirious1520 &raquo;</TD></TR><TR><TD CLASS="quote">If its not the exhaust, does anyone have any suggestions, any sensors? </TD></TR></TABLE>
just wait until you get the correct downpipe.
Old Dec 21, 2005 | 01:34 AM
BB4vTak's Avatar
Default Re: h22a in 92 lude (H23 Power)
Not having a down pipe on it will NOT prevent it from running correctly....it will just be a lot louder than usual... it would be better to have one on.. but if its not running... you're going to have the same problem after a DP is installed
Old Dec 21, 2005 | 04:40 AM
kulrevon's Avatar
Default Re: h22a in 92 lude (BB4vTak)
after you tried to start it did you pull the check engine codes to see if you have any?
Old Dec 21, 2005 | 09:53 AM
SteveoBA8's Avatar
Default Re: h22a in 92 lude (kulrevon)
He should have an o2 cel since its not even plugged in, dude just wait till you have everything together, then start your diagnosis.
project93cpe
Nov 30, 2007 07:46 PM
SiR Damo
Mar 14, 2007 07:26 AM
delirious1520
Dec 23, 2005 08:00 PM
RudeLude
Jun 5, 2004 05:58 PM
Accord94DX
Sep 23, 2002 08:56 AM
