99 acoord headlights
Old Dec 20, 2005 | 04:54 PM
nelson79's Avatar
Default 99 acoord headlights
hi hope someone can help is there a way i can have my headlights fully on what i mean by this is low and high beam at the same time without any damge please let me know thanks.
Old Dec 20, 2005 | 05:52 PM
hondaccord2000's Avatar
Default Re: 99 acoord headlights (nelson79)
I have a 2000 Accord and when you turn on your high beams, your low beams are still on. I assume it's the same on your car.
Old Dec 20, 2005 | 11:02 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nelson79 &raquo;</TD></TR><TR><TD CLASS="quote">hi hope someone can help is there a way i can have my headlights fully on what i mean by this is low and high beam at the same time without any damge please let me know thanks.</TD></TR></TABLE>
you can, like nelson said, just pull the level back and your highbeam is on so is your lowbeam.
but i guess the big question is why you want to drive with highbeam on all the time. not to mention it's illegal
Old Dec 21, 2005 | 12:08 PM
nelson79's Avatar
Default Re: 99 acoord headlights (iam7head)
hey thanks for the replys all i want is for the whole headlight to be on, this is the way i have it , i have the signal light on then i have the day time running lights then the high beams section is off obviously i want everything working i want the high beam to be the same brightness as the day time running lights is that possible or am i asking too much, it would just look better with everything on
Old Dec 21, 2005 | 01:12 PM
philadd's Avatar
You would need different relays, which probably aren't available since you have DRLs. Because the DRLs are just the high beams at a lower power, it's not a good idea to have them on at night. Even at the lower power there is still enough glare (because the high beams are aimed higher) to cause problems for oncoming drivers at night.
1991 DA
Aug 13, 2006 09:16 PM
fthesys
Apr 2, 2006 08:43 PM
MLKs2k
Honda S2000
Feb 24, 2005 12:33 PM
dreemz
Mar 16, 2004 02:11 PM
