H23 stage 3 camshafts
Old Dec 20, 2005 | 04:47 PM
92bluepreludeSi's Avatar
Default H23 stage 3 camshafts: CAR STARTED woohoo!
I'll have everything tomorrow for my head swap. Haveing the head cleaned, valve job etc... just waiting on the RM springs and retainers. heres a list of everything i've bought for the head swap.
-Crower stage 3
-RM spr/ret
-supertech std. size valves
-KMS high flow oil pump
-Prostreet timing belt kit
-ARP head studs
-complete head gasket kit
im hoping to have the head off my car tomorrow and have the new one on by the weekend. Here's some pics to hold you guys off >
Modified by 92bluepreludeSi at 8:07 PM 1/13/2006
Modified by 92bluepreludeSi at 8:08 PM 1/13/2006
Old Dec 20, 2005 | 04:54 PM
flyrod's Avatar
Default Re: H23 stage 3 camshafts (92bluepreludeSi)
Nice! You are swapping SOHC for DOHC? Or just a replacement head? Good luck and keep us posted. I would be interested in hearing about your experience tuning those cams, especially the idle.
Old Dec 20, 2005 | 04:56 PM
h23civic's Avatar
looks like it'll produce some great airflow for that head. i hope to do something similiar to my h23, either that or build an h23vtec, haven't quite decided yet. looks good man
Old Dec 20, 2005 | 05:37 PM
PirateMcFred's Avatar
Sweet! Someone I can relate to. That looks pretty nice. I'm with flyrod, the tuning will be an experience. What ECU are you going to run? What are your goals? Good luck with those. Kudos for trying something different. How much did you pay for the valves? where did you get them?
Pirate
Old Dec 20, 2005 | 05:59 PM
Default Re: H23 stage 3 camshafts (PirateMcFred)
Im replacing my dohc with the new and improved one I paid 290 for the valves! yea... 333 with shipping. crazy. Got them from at importperformanceparts.net. Still going to use the stock ecu. i only have an safc. Dont really have too high of goals. Just want to see how this works out and see what the results will be. Can anybody tell me what to expect from the idle? I'll keep you guys posted!
Old Dec 20, 2005 | 07:13 PM
First off pull out a LOT of fuel at idle or it will probably not run below 2000 rpm on initial startup. I really really recommend something other than the SAFC for tuning. Once you get the air/fuel right then it will be about like this:
http://www.we-todd-did-racing....DE%3D
(right click, save as, quicktime format)
but you can spend a lot of time with timing and idle screws and whatnot and get it down to a really lumpy 800rpm. The clip above is with a crappy exhaust and idling at about 1000 rpm from about 9 months ago. My power peaked at 6500 rpm dyno on basemap link in sig. But I am not a regular H23 build.
Pirate
Old Dec 20, 2005 | 08:21 PM
wow that sounds crazy. Are you using anything to tune it? you wouldnt happen to have a clip of it reving, do u? thx
Old Dec 20, 2005 | 09:14 PM
Not right now. I might be able to come up with something tomorrow though. I have a tuned P28 with custom fuel and ignition maps.
Pirate
Old Dec 20, 2005 | 09:18 PM
Hawkze_2.3's Avatar
Good luck It's good to see not everyone is going H22.
Old Dec 21, 2005 | 04:55 AM
PhAnToM_Eh2's Avatar
Default Re: H23 stage 3 camshafts (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Good luck It's good to see not everyone is going H22.</TD></TR></TABLE>
exactly let me know your results when u get some numbers im very interested to see your numbers
Old Dec 21, 2005 | 03:11 PM
where did you get the p28 from? phearable? Oh.... in the crower manual it says that the lube is for a quick break in. How do you break the cams in?
Modified by 92bluepreludeSi at 4:24 PM 12/21/2005
Modified by 92bluepreludeSi at 4:32 PM 12/21/2005
Modified by 92bluepreludeSi at 4:41 PM 12/21/2005
Modified by 92bluepreludeSi at 5:06 PM 12/21/2005
Old Dec 21, 2005 | 06:30 PM
I got the ECU from a junkyard and had Flyrod convert it to a P28 and I tuned the maps.
I used Crower's assembly lube and followed the procedure outlined in the little booklet that came with the cams.
Oh, here's a sound clip I found:
(right click, save as)
http://www.we-todd-did-racing....5NTQx
Pirate
Old Dec 21, 2005 | 07:18 PM
SteveoBA8's Avatar
lol, sounds pretty sweet
Old Dec 22, 2005 | 04:35 AM
Default Re: H23 stage 3 camshafts (SteveoBA8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">lol, sounds pretty sweet</TD></TR></TABLE>
well if you like that you'll probably like this one a lot better.
Pirate
Old Dec 22, 2005 | 10:34 AM
SteveoBA8's Avatar
mmnnnnn, non vtak power
Old Dec 22, 2005 | 11:29 AM
that sounds nice
Old Dec 23, 2005 | 04:08 PM
alright, finally got my RM springs and retainers in today. Took them to the shop to have the springs, retainers, valves, and vavle stem seals installed. should have it back on tuesday. I'll have my car prepared for the swap by then.
Old Dec 23, 2005 | 08:03 PM
lude of pre 2.3's Avatar
nice set up man just make sure the cams are degreed right and the cars tuned good luck
Old Dec 24, 2005 | 11:46 AM
LudeyKrus's Avatar
Good, it's about time someone else threw this bad boys in to see what a non-vtec can pull!
Keep us updated.
Old Dec 26, 2005 | 05:02 PM
Default Re: (LudeyKrus)
ok, i got my head off and everything on the front off. Looks like my engine was rebuilt before i bought it. head looked brand new, block looks brand new, all the internals look brand new. Its crazy!
Old Dec 26, 2005 | 06:12 PM
Default Re: (92bluepreludeSi)
Mine looked like it had been worked on too. It was not very good work though. Glad to hear that you're making some progress.
pirate
Old Dec 26, 2005 | 07:38 PM
Default Re: (PirateMcFred)
yea... mine had work for sure. but my timing belt and balance shaft belt were real loose. Could explain why i it didnt pull at all after 4500 cuz of the timing belt. When i get my head back tomorrow i'll post some pics and pics of my engine torn down. I know you guys have seen that kind of stuff... but eyecandy is good!
Old Dec 29, 2005 | 07:10 AM
hey pirate, were your RM springs longer than stock? Cuz the machine shop just called me saying that the springs are too long and they are afraid its going to spring bind.
Old Dec 29, 2005 | 07:55 AM
IIRC they were shorter. But there were big differences in the retainer and what not. Tell them that they work fine for me and have for abot 10K miles at .451" lift.
http://www.we-todd-did-racing....D.jpg RM S&R installed comparison
http://www.we-todd-did-racing....D.jpg RM S&R set
http://www.we-todd-did-racing....D.jpg stock retainer
http://www.we-todd-did-racing....D.jpg RM retainer
I am sure that RM could tell you specific specs that the shop should look for.
Pirate
Old Dec 29, 2005 | 08:50 AM
yea my springs dont look like that! omg. I think the guy sent me the wrong springs, cuz the ones i have are a lot more slim. The guy at the machine shop is having trouble finding a seat cuz they are not the same size. I might have to put my old head on now. i bought the rm spring set from dfoxengr and he says that he sent me the H23 springs.
edit: Forgot to say that my springs dont sit on the spring seat properly cuz they are smaller in diameter.
Modified by 92bluepreludeSi at 10:13 AM 12/29/2005
Modified by 92bluepreludeSi at 10:16 AM 12/29/2005
