90 Civic STD...SOHC VTEC problems
Old Dec 20, 2005 | 02:29 PM
Blanket Jackson's Avatar
Default 90 Civic STD...SOHC VTEC problems
I have a 90 Civic Hatch DX, with a D16Z6. I just replaced the headgasket on the motor a few days ago for I had to replace the motor with a new block. The car ran good for a couple days then began to run like ****. It will not rev over 3500rpm's now. What could the problem be?
Old Dec 20, 2005 | 02:33 PM
dr_latino999's Avatar
Default Re: 90 Civic STD...SOHC VTEC problems (ExcessivePerformance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExcessivePerformance &raquo;</TD></TR><TR><TD CLASS="quote">I have a 90 Civic Hatch DX, with a D16Z6. I just replaced the headgasket on the motor a few days ago for I had to replace the motor with a new block. The car ran good for a couple days then began to run like ****. It will not rev over 3500rpm's now. What could the problem be?</TD></TR></TABLE>Your ECU has to be throwing a code if it WON'T rev past 3500. Tell us the code and we'll work from there.
Old Dec 20, 2005 | 03:00 PM
It is throwing a 1. But I think the wiring might be messed up.
There was a problem with the fuel pump a few weeks ago. I put a used tank on it that had some buildup matter, and it clogged my pump. I replaced the pump the day I replaced my headgasket. Could that be a prob?
zerobytegeek
Nov 14, 2008 02:40 PM
teggy2154
May 8, 2008 06:57 PM
JasonKarl
Jan 30, 2008 07:37 AM
Eee Kay Nine
Jan 22, 2007 02:34 PM
